Results 1 to 7 of 7
Thread: Errors on 1.2
    Variable Bitrate bns2000's Avatar
    Nov 2004
    Russellville, AR
    Errors on 1.2
    I have found 3 errors in Centrafuse 1.2 With Vista
    1.) The start button is not hiding so it shows threw Centrafuse sometimes.
    2.) When the Pause button shows its off a little, but not when it shows Play.
    3.) The back button it off a little too. But not when the X is there.
    Also I to had the error when installing Centrafuse. But then I uninstalled my old centrafuse and it went away.
    CENTRAFUSE™ From Flux Media
    The Ultimate Infotainment Interface
    Download V1.20 from there site now!!!!
    Download the new 2.0 RC1 From here Linky
    VENDOR - Centrafuse veetid's Avatar
    I am uploading what should be the last 1.2 installer now and will post when it is finished...
    I spent awhile improving Vista support to make most all data write to LocalAppData instead of ProgramFiles and the install should be seemless with UAC enabled...
    david
    Nov 2004
    Russellville, AR
    David, I uninstalled then reinstalled with the new installer and it's still is the same. I have posted my log if it helps any.
    Attached Files Attached Files
    Quote Originally Posted by bns2000 View Post
    so you still got the dxsetup.exe error? this should have been gone... The graphics errors, DVD issue in the log, and the TimeZone issue in the log are all known issues we will get working in Vista soon...
    david
    Nov 2004
    Russellville, AR
    I said that in the first post. I was just telling you that uninstalling 1.14 took it away.
    I know but this should have been fixed in the new 1.2 installer, I changed the way dxsetup was called...
    david
    I see what you are saying now I believe... not had much sleep in the last few days...
    you cannot test the one issue with dxsetup because it only happened with 1.14 installed...
    david
  1. 1.2 Farad Voodoo Cap.. NEED HELP!
    By Yacob in forum Power Supplies
    Last Post: 11-05-2006, 05:33 PM
  2. Bluetooth 1.1 or 1.2? am I being fooled
    By tryme in forum Wireless Communications
    Last Post: 02-09-2006, 11:58 AM
  3. CF 1.4 skin for CF 1.2
    By superbowl in forum CF Skins
    Last Post: 08-08-2005, 05:19 AM
  4. Destinator problem in 1.2
    By RoyN in forum Centrafuse
    Last Post: 02-19-2005, 12:24 AM
