Results 11 to 20 of 26
Thread: Centrafuse 1.2 bugs
  1. #11
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    midiwall: can you remove plugins until you can determine or make sure it is one of the plugins causing this error?
    It looks like it things there is an image to paint in a listview, but it is not in the image array for some reason... this might be from the new XM plugin actually, I was working with Scott to fix a similiar error just yesterday...
    No probs, I'll play with it.
    Scott did mention that you guys had been working on something similar and that this may be fixed in the next CF build.
    More when I know more!
    :: Mark
  2. #12
    Jul 2006
    if you add an equalizer preset with the same name as a current entry, it puts both of them in the list. however, if you then delete one, it deleted both. perhaps an overwrite request dialog or addition of a (#) afterwards would solve this
  3. #13
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    This was due to the favorites icon bug in the Satellite radio plugin, you shouldn't be getting this anymore...
  4. #14
    Low Bitrate marci's Avatar
    Jul 2007
    Switzerland
    is there a special Multi monitor function in CF 1.2 (1.3) ? i use a dual monitor system with infill g4 car pc (TFT touchscreen with res.800x480), and as addon Monitor a TFT Touchscreen with res 800x600. All works most of time fine, but when i go to settings menu, take as sample the audio/video menu, the screen after is on the upper display, when i want change something, i must edit it at the other monitor ;-) Crazy :-)
    and: when i navigate, the navi displays at the 800x600 display, but not with the 800x600 resulution only at 800x480
    see:
    maybe i need to much :-) so im feel ok with CF :-)
    Phone:
    only all of my windows mobile 5 devices, cannot install the phone control utility to the windows mobile 5 devices. (security lock) why the phone control manufactor donīt release this utility as *.cab file for manually installing ? ;-)
    but i will search the www :-)
    bg
    marci
  5. #15
    VENDOR - Centrafuse veetid's Avatar
    I will look into this... most of the dual monitor setups are designed for video, DVD, and visuals... The navigation was added, but you are right it will run in the same resolution as the primary monitor...
    david
  6. #16
    Jul 2007
    Switzerland
    no problem, i must fix first some EMV related things :-) Later should be running on the upper display, dvd, television, navi and some other external applications. one of the biggest goal is, that when you have an extended Dual Monitor Setting, the mouse scrolls from left screen to right screen. but: i have no dual monitoring with left and right monitor, i habe a upper and a lower Monitor ;-)
  7. #17
    that is more of a windows issue... will windows not allow you to stack monitors?
    david
  8. #18
    Jul 2007
    Switzerland
    Hi david, yes thatīs right, Dual Monitoring and the direction of expanded screens are Video Card Driver issues. :-) Centrafuse is the best (commercial) tool at the moment on the market, i bought a licence, i feel good with cf :-) I wil try the monitor problem with vista too, next time i have time. many users ask me, if there come a solution for Multimonitoring the next time.
    But first i have so resolve my EMV problems.
    I think many people are very happy, if you found an option in CF, that can restart an connected USB Hub (or delaying a USB Boot Init/reset Signal after restart from standby or hybernating) many users come from hybernation and the external USB Touchscreencontroller or USB GPS mouse dont work again. (only if you disconnect and reconnect the device)
    With adjustable Boot Parameters that was a great Idea :-) I have the problem with my external USB Port Replikator and restart from hibernation. sometimes the Grafikcard on USB hub is not fast enough to init, and then all applications displays on the lower Display again. I need an option that allow only run some applications on the second (upper) monitor... questions over questions, but thatīs not your issue, your users need other things and this is much more important :-) I find always solutions if i had the time to find them ;-)
    bg marci
  9. #19
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by marci View Post
    I have exactly the same problem with my Bluetooth dongle which need sometimes (note every times) to be disconnected and reconnected to be detected after restart from hybernation.
  10. #20
    Jul 2006
    read through this thread, he gives very easy to follow step-by-step instructions on disabling/enabling devices during standby or hibernation
    http://www.mp3car.com/vbulletin/faq-...de-devcon.html
  1. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 10:28 AM
  2. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 08:11 PM
  3. Centrafuse RC5 Bugs
    Last Post: 02-26-2007, 05:00 PM
  4. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 01:48 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
