Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Centrafuse 1.2 bugs
    Jun 2005
    Slovenia
    Centrafuse 1.2 bugs
    Hi all,
    I see there's no 1.2 bugs thread yet. How about we start one?
    I've noticed that there seems to be a problem with loading Album art. I have turned off album art (as always) but I still have some mp3s that contain album art. Now I have the same album art picture no matter what mp3 I choose.
    I haven't installed it on my carpc yet since I'm waiting for the ability to purchase it and get a regular serial - or at least something that will make the 'register now' window dissappear - so I can't comment on other things yet.
    VENDOR - Centrafuse veetid's Avatar
    I will look into this...
    david
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Skin bug are stil present in 1.2.
    I can't see any mistake in XML skin file.
    The problem doesn't appear in all resolution.
    only in full screen mode and wide resolution on my 4:3 screen.
    XP PRO SP2
    CF 1.2 (version downloaded on CF site on 23th june)
    I will get the resize issue fixed...
    the blue line is from resizing the skin images in .NET, it can leave artifacts sometimes... it's not a mistake in the XML or anything... I will try to fix it...
    david
    Newbie LEiPiE's Avatar
    Aug 2006
    The Netherlands
    Don't really like to submit bugs, 'cause I really like CF and am looking in to actually buying it. Just installed the trial download yesterday: first of all it exited because of an .net install error, but not telling me why/what/where. Only after manually starting the .net updater (from the temp files dir that was still there), did I find out .net needed a reboot of the machine because of some windows updates that needed a reboot.
    After that install was no problem whatsoever.
    After setup it ran for the first time, welcoming me with a "this beta has expired, please download the new version" or something along those lines. Erm, I just downloaded the newest version from the website
    And it still has some bugs already present in previous versions:
    - library sometimes gets the artist's name wrong but are sorted by the real artist's name ('Genesis' is not that odd a name for a group now, is it? )
    - CAM doesn't use full resolution, even if set correctly, it still shows a blocky image while the TV card's own software show a much cleaner picture
    CarPC: "Carma" (Car Audio & Route Management) (about 70% ready)
    P4 1.8GHz / 512MB / 4GB CF
    Asus TVFM + B/W camera
    15" touchscreen 1024x768
    BU303
    2x 100Ah
    reinstalling
    And all this in a Dutch 1972 Citroën HY van called "MurpHY".
    you should be able to set the CAM resolution....
    As for the install errors, the previous Beta's must be completly removed from the system... This is a license issue, it picked up an old license from a Beta... You need to completly uninstall all versions of Centrafuse, then manually delete the" C:\Program Files\Flux Media" folder before installing Centrafuse...
    david
    May 2006
    Seattleish, WA
    Hey David... I'm getting this in the error log at a rate of about 15 per minute:
    Code:
    9/5/2007 4:59:49 PM
    Index was out of range.  Must be non-negative and less than the size of the collection.
    Parameter name: index
       at System.Collections.ArrayList.get_Item(Int32 index)
       at centrafuse.Plugins.skinListbox.OnPaint(PaintEventArgs pe)
    :: Mark
    Oct 2004
    not shure if this has been brought up but, if i already have no playlist in que then go and select a folder i wanna play the playlist number goes from 0 to 10 instead on 1, and all the other ten are ussualy blank. then when playing videos sometimes when a video is done it will jsut stop and freeze and not move on to the next video, i have to actaully manualy press next.
    midiwall: can you remove plugins until you can determine or make sure it is one of the plugins causing this error?
    It looks like it things there is an image to paint in a listview, but it is not in the image array for some reason... this might be from the new XM plugin actually, I was working with Scott to fix a similiar error just yesterday...
    nadforever: These should both be fixed in 1.30, I did work on video playback and on the playlist counting issues...
    david
  1. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 11:28 AM
  2. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 09:11 PM
  3. Centrafuse RC5 Bugs
    Last Post: 02-26-2007, 06:00 PM
  4. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 02:48 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
