I will check this out...
I assume you are talking about the speech enabled flag in Centrafuse... When disabled does it stop reading SMS messages? I am not sure if I control the reading of the incoming call, but I will verify...
david
I posted this in the phoco forums, but zorro said it may be a CF issue?
"I have speechenabled set to false, yet I still hear "incoming call from XXXXX" when I recieve a phone call. "
http://zhorvat.dyndns.org/PCForums/S...px?PostID=5386
david
Ok, I think I got it to work. I simply forgot to close CF entirely and restart it. I didnt even think about it and did it for a different reason, and found that the sounds were gone.
I'll let you know if that was not the case, but it seems okay for now.
However, I did find a few more bugs that you may be interested in with regards to phoco.
A few times before restarting and correcting the above issue I could hear the voice say "incoming call from xxx," however, the dialog did not pop up and the music did not resume. This happened a few times in a row. I think I closed CF and restarted it to get things working again.
Second thing is when playing XM radio and an incoming call is accepted, the music pauses fine, but when it resumes, the volume drops a lot. Its not the main, pre, or line-in volume as I looked through the mixer and levels control and all were normal. When I switched to media, and then back to XM, the volume level bumped back up to normal. I never touched the volume control.
There were a few more... but I honestly can't remember right now. I'll report back when I do.
