Any specific settings you changed? Any thing you can modify to make it not happen to help track down the cause? Disable navigation on page 3 of navigation settings, disable phone, only load at the main screen, etc...
david
Everytime I hibernate my carputer, if centrafuse is open, when I resume from hibernation centrafuse has close.
It only happens since I've installed centrafuse 1.20...
david
Mmm... now that you tell it, althought I don't remember to have change anything (but maybe I did), since I installed 1.2, when centrafuse starts it suffer a little delay, taskbar appears and it seems "Destinator" in a new tab; I will try your advice.
Also whether it is Vista or XP could make a huge difference... There are some reports of resume issues on Vista we are looking into to...
david
Ok, fixed, since I disabled navigation, it works ok... but navigaton doesn't work, naturally...
Ok, I will try... in fact, bluetooth com port is not always enabled: only some times I switch on bluetooth gps.
Ok, I've tried and wherever the com port that I enable, it doesn't work if I enable navigation in the 3rd page of NAV
Well, it is a bluetooth gps...
I will try to open another gps program, thanks
