Code:
7/9/2007 7:44:15 PM
Could not find a part of the path "C:\Documents and Settings\Travis\Application Data\CFBluetoothControl\Temp\".
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.Directory.InternalGetFileDirectoryNames(String fullPath, String userPath, Boolean file)
at System.IO.Directory.InternalGetFiles(String path, String userPath, String searchPattern)
at System.IO.Directory.GetFiles(String path, String searchPattern)
at CFBluetoothControl.BluetoothControl.UninitBluetooth()
7/16/2007 10:44:21 AM
7/16/2007 2:57:54 PM
7/16/2007 3:42:49 PM
7/16/2007 3:56:03 PM
7/16/2007 3:58:31 PM
Specified cast is not valid.
at CFBluetoothControl.BluetoothControl.itemList_SelectedIndexChanged(Object sender, EventArgs e)
at centrafuse.Plugins.skinListbox.SetSelectedIndex(Int32 pi_iNewIndex)
7/16/2007 3:58:34 PM
Object reference not set to an instance of an object.
at CFBluetoothControl.BluetoothControl.ShowFtpFolders()
at CFBluetoothControl.BluetoothControl.forward_Click(Object sender, MouseEventArgs e)
7/16/2007 9:42:18 PM
at CFBluetoothControl.BluetoothControl.refresh_Click(Object sender, MouseEventArgs e)
at centrafuse.Plugins.skinButton.fireClick(MouseEventArgs e)
at centrafuse.Plugins.CFPlugin.CFPlugin_MouseUp(Object sender, MouseEventArgs e)
7/23/2007 7:15:07 PM
7/23/2007 7:25:55 PM
7/23/2007 7:33:27 PM
7/24/2007 9:57:18 AM
7/24/2007 1:51:50 PM
7/25/2007 10:07:41 AM
