The log is located in "LocalAppData\Centrafuse\error.log"
I would find this file, delete it, then load Centrafuse, then post the new file so it only contains the error we are trying to fix...
You might try removing your plugins by moving the folders out of the ProgramFiles\FluxMedia\Centrafuse\Plugins folder, then if it loads add them back one at a time and see if it is a plugin causing the issue...
david
LinkBack URL
About LinkBacks
