Are you running Vista? If so then this is a Vista issue we need to get fixed... You do not have permissions to save files to the favorites folder, if you run as admin it will most likely work...
david
As above, I can't add a site as a favourite.
I click on the * to get the list, then on + to add a new.
When I type the address in and Enter, nothing happens.
Also, when I click on the keyboard and try to go to a site manually, nothing happens when I press Enter there either.![]()
david
I'm running XP Pro David, sorry.
And my user has full Admin rights.
Even that wouldn't stop me being able to enter a manual address though, surely?
I think a temporary workaround would be to open IE outside CF and add the favourite there. I'll give that a try tomorrow - unless the CF favourites are stored separately?
I will look into this... The favorites are stored in the same location that IE stores them...
david
