I'm trying to use the new XM plugin on 1.40 (and 1.30) and I cannot get it to control the audio line in. This is running on Vista Ultimate (UAC disabled). It will not unmute/mute the line-in on which the XMDirect is connected. If I go to the Sound CPL and flip the settings, I get XM sound, but Centrafuse just doesn't seem to want to control it. I've configured it to use the right line-in in the XM settings screen.
I've also tried a different USB audio adapter with same results.
Here's the beginning of the XM log file:
Code:
25:58:16>
26:03:18> startupRadio()
26:03:25> satPowerUp(0)
26:03:25> satPowerUp(): Opening COM10
26:03:71> satPowerUp(30)
26:03:71> satPowerUp(): Opening COM10
26:03:73> RxThread Entering
26:03:73> tuneChannel(): 30
26:03:73> satStationInfo()
26:03:74> satStationInfo()
26:04:26> doCommand(): Writing currentCMD = XM_UNMUTE
26:05:06> doCommand(): Writing currentCMD = NO_COMMAND: 5A A5 00 04 25 08 1E 00 ED ED
26:05:30> musicLst_DoubleClick(): musicLst.SelectedIndex = 26
26:05:30> musicLst_DoubleClick(): newchannel = 30
26:05:31> tuneChannel(): 30
26:05:31> satStationInfo()
26:05:46> musicLst_DoubleClick(): musicLst.SelectedIndex = 26
26:05:46> musicLst_DoubleClick(): newchannel = 30
26:05:46> tuneChannel(): 30
26:05:46> satStationInfo()
26:05:50> musicLst_DoubleClick(): musicLst.SelectedIndex = 26
26:05:50> musicLst_DoubleClick(): newchannel = 30
26:05:50> tuneChannel(): 30
26:05:50> satStationInfo()
26:05:89> RxThread(): Bytes=00 1B 80, satSize=28
26:05:89> RxThread(): OpCode = 80, satState = PowerON
26:05:99> RxThread(): Processing 28 bytes
26:05:99> RxThread(): Calling ProcessSat(): Bytes=01 00 00 25 10 29 20 02 01 00 00 01 74 04 05 20 02 08 4A 52 5A 50 32 30 57 59 00 59
26:06:02> ProcessSat(): %) t JRZP20WY Y
26:06:06> RxThread(): Bytes=00 4D A5, satSize=78
26:06:06> RxThread(): OpCode = A5, satState = StationInfo
26:06:16> RxThread(): Processing 78 bytes
Any suggestions? Other info I can provide to shed some light?
Update: I've managed to get XM turn off properly when closing Centrafuse (XM audio goes away); however when starting Centrafuse again, it never starts up again with XM, it always starts Media. Switching to XM will start-up XM ok (XM audio starts up), but XM will continue to play when switching back to Media. Also, Centrafuse volume control has no affect on XM.
Thanks,
Dalen
