Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Centrafuse 1.40 Bugs
    Jul 2005
    The aura skin the setting levels part of the skin the background is black behind the bass and treble controls.
    I have the autovolume plugin installed, every time a change to the volume is made the volume splash screen pops up.
    I have enabled the gestures, they do work but its now difficult to press a button, I guess I need to play around with the parameters to improve things. Some explanation of the parameters would be useful.
    VENDOR - Centrafuse veetid's Avatar
    The main mixer screen was a bug, I fixed this and posted a new centrafuse.exe for CF 1.41 here:
    http://forums.fluxmedia.net/showpost...96&postcount=3
    I need to add a method in the SDK so the volume plugin can change the volume without firing the dialog to display, I will add this to my list...
    david
    As I said, we had some issues with gestures and we mainly focused on the gestures on the list views...
    The gestures.xml has basic settings...
    ENABLEGESTURES = True/False - enables or disables gestures
    GESTUREOFFSET = This is in pixels and is how much change on the screen determines a gesture, so if click the mouse and you move this pixel amount, it registers as a gesture
    DETECTIONTIME = This is the amount of time in ms to look for the pixel change in the offset above, so the on mouse down it starts to wait the detection time, checks how much you moved and compares to the offset. If the offset amount has changed, then it's a gesture, otherwise continue with a normal button press
    GESTUREDISTANCEX = This is the amount of pixels before firing the gesture when moving left/right
    GESTUREDISTANCEY = This is the amount of pixels before firing the gesture when moving up/down
    GESTURE1-4 = These are the actions you can set, GESTURE1 is moving UP, GESTURE2 is moving to the RIGHT, GESTURE3 is moving DOWN, and GESTURE4 is moving to the LEFT
    david
    Jul 2005
    Thanks for the info when, my car is stationary pressing the buttons is not a problem, when moving I guess theres a movement greater than 3 pixels. Going to try differnt values. I will report my findings.
    Jul 2005
    Using a gestureoffset = 10 and Detectiontime = 250 works fine for me.
    Quote Originally Posted by clarkie View Post
    does having the detection time as high as 250 not make it seem like it lagged when clicking normal buttons?
    david
    Jul 2005
    No seems pretty normal to me
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    With experience in STOKEIT (gesture software), I think gesture should be applied "on click release" instead of "on click".
    Nov 2004
    FRANCE
    The skin bug around the PLAY/PAUSE button is still present (like an offset of 1 pixel up + 1 pixel left make appear a blue line)
    This bug is highlightened with the new Aura skin.
    Nov 2004
    FRANCE
    Volume bug
    This was present since 1.2.
    When you are in fullscreen mode playing a video, you can't let the volume button push in order to increase volume continuously.
    When playing MP3, you can.
  1. Centrafuse Beta 1.40
    By veetid in forum Centrafuse
    Last Post: 11-12-2007, 10:29 AM
  2. Centrafuse 1.11 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 04-16-2007, 11:28 AM
  3. Centrafuse 1.1 Bugs
    Last Post: 03-13-2007, 09:11 PM
  4. Centrafuse RC5 Bugs
    Last Post: 02-26-2007, 06:00 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
