virtualizations
I have 1.44 and when the computer resumes from standby the virtualizations are all gone, i have to restart centrafuse to get it all back.
songs on USB bar sometimes does not play i have to press next and back to get it to start working, This perhaps may be a compatibility issue as when i press the USB button it says no usb storage devices, but recognizes another USB flash drive that i have fine, I will try this out to see if it does the same also.
I will look into the visualization issue...
with the USB, you can have a USB device plugged in, and it will say no USB device found but still load?
can you reproduce that easily?
david
yes every single time with this particular USB bar. Its a LG 256mb. As I said I have another USB bar and it works fine?? not a big issue for me... perhaps for others..
visualisations still not comming back on after standby. downloaded and installed 1.46. seems like its an intermit problem. When I restart centrafuse the visualisations come on fine and sometimes will work after resuming from standby. When it stops working however it will never come back unless I restart centrafuse again.
