I will look into the visualization issue...
with the USB, you can have a USB device plugged in, and it will say no USB device found but still load?
can you reproduce that easily?
david
I have 1.44 and when the computer resumes from standby the virtualizations are all gone, i have to restart centrafuse to get it all back.
songs on USB bar sometimes does not play i have to press next and back to get it to start working, This perhaps may be a compatibility issue as when i press the USB button it says no usb storage devices, but recognizes another USB flash drive that i have fine, I will try this out to see if it does the same also.
david
yes every single time with this particular USB bar. Its a LG 256mb. As I said I have another USB bar and it works fine?? not a big issue for me... perhaps for others..
visualisations still not comming back on after standby. downloaded and installed 1.46. seems like its an intermit problem. When I restart centrafuse the visualisations come on fine and sometimes will work after resuming from standby. When it stops working however it will never come back unless I restart centrafuse again.
