The music volume lowers, sat nav speaks, then volume shoots back up to max for a slit second before returning to normal volume. quite annoying if the music wasnt very load to start with.
Is it just me or anybody else have the same problem?
Printable View
do you have use pre as master or use front speaker options turned on in settings? reports these are causing this issue, I am looking into it... if so try to disable these and see if it stops...
david
Yes i am using pre as master. Will try changing it and see if it helps. This might explain why the ATT isnt working either.
At the moment i can change the satnav vol using settings.ini, but have no control over how much the music turns down. Maybe this should be looked at and an option to set it. Some people may want it turned down all the way, wheras i would like to turn it down maybe 20% while the sat nav speaks.
I have found that the volume that the music returns to for a split second is the ATT volume. So it goes from Normal -> Lower (satnav speaks) -> att vol -> Normal Vol
It should go from normal to att volume for sat nav and then smoothly back to normal
in the config.xml there is ATTVOLUME flag which lets you set this volume, I also have added an option to put it back to pause like it was before...
also adding all these settings to the settings screen so no file editing will be neccesary...
david
