can you post your error.log file
david
Hi,
I have the Centrafuse 1.20 with 1.47 patch, I have install Power DVD 7.0 Cyberlink and when I push the exit Button the DVD not exit ...
And when I load the Media and I want to load the CD audio, I press the exit button and the cd Open, but when I push the button for close the CD not work...
Help !!!
david
hello,
I don't have a error, and I don't have a file error.log ....
The button not work and not generate a error... :-(
What I can do ???
the error.log would be located here...
"C:\Documents and Settings\<username>\Local Settings\Application Data\Centrafuse\error.log"
david
But when I push the exit button and don't work, there isn't a error.log....
I use the Cyberlink Power DVD 7 ... I must use another program ?
which version are you using? try the latest 2.0 and see if this is still an issue...
david
