Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: hdradio bug
  1. #11
    MySQL Error
    Oct 2004
    sure does
    in my install (VISTA)
    C:\Users\mitchjs\AppData\Local\Centrafuse\RadioMod ules\HDRadio
    there is a file
    HDRadio.xml
    and the contents of the file
    Code:
    <HDRADIO>
      <VOLUME>75</VOLUME>
      <COMPORT>3</COMPORT>
    </HDRADIO>
    are you running XPE of compact flash?
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    Oct 2004
    i am running xp pro on my computer i had it on the last RC (rc2) just dont have the folder this time for some reason.
  3. #13
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Such a path does not exist on my XP SP2 machine.
    I do not have a login.
    The 'Administrator' has no "Local Settings" directory.
    ANd do you have Windows explorer to show hidden files and folders? LocaAppData is a hidden location by default, but you probably already knew that, just making sure...
  4. #14
    Jan 2008
    Quote Originally Posted by smeesseman View Post
    Thanks.
    I did not realize that there could be hidden folders as well as files.
    Anyway, I enabled "Hidden Files and Folders" in Windows Explorer, edited the HDRadio.xml so the volume is 80 instead of 35, and all is well with the volume issue now.
  5. #15
    Jan 2008
    Exclamation
    Quote Originally Posted by mitchjs View Post
    sure does
    there is a file
    HDRadio.xml
    Code:
    <HDRADIO>
      <VOLUME>75</VOLUME>
    </HDRADIO>
    mitch
    Mitch,
    I have radio Buffering OFF.
    Did you ever have trouble in RC3 with CF failing to UNMUTE the Playback Line-IN (line-in on my sound card) when moving from Music to HDRadio?
    I start CF in HDRadio. The first time I move from HDRadio to Music, CF mutes the playback line-in as it should so I can hear the WAV output.
    But I then move back to HDRadio from Music, and line-in stays muted.
  6. #16
    Mar 2007
    Detroit, MI
    All HD radio issues should be fixed as of CF V 2.0.626
  7. #17
    VENDOR - Centrafuse Jan_RedGTiVR6's Avatar
    May 2008
    Thread closed since there has not been a response from the OP in over a month.
    Jan Bennett
    Centrafuse Support
  1. Gesture based bug recorder/tracker
    By Iceman_jkh in forum Road Runner
    Last Post: 12-25-2007, 09:28 PM
  2. StreetDeck Bug Reporting System
    By RedGTiVR6 in forum StreetDeck
    Last Post: 12-10-2007, 02:07 PM
  3. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 03:12 PM
  4. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 01:27 AM
