HDRadio volume extremely low with CF RC2
Can you try cranking up the volume?
RC2 seems to set the Directed HDRadio volume very low.
I can hear it if I turn the volume way up.
If I first let the normal Directed controller bring up the radio, and then plug the audio in to my sound card, the volume is fine.
HDRadio.xml file not there
Quote:
"C:\Documents and Settings\David\Local Settings\Application Data\Centrafuse\RadioModules\HDRadio\HDRadio.xml"
you can set volume levels and COM port in this file and restart Centrafuse...
Such a path does not exist on my XP SP2 machine.
I do not have a login.
The 'Administrator' has no "Local Settings" directory.
PLEASE move this config data to a central place.
These are Car PCs, not general-use PCs.
No need for individual users!!
