Results 1 to 10 of 17
Thread: hdradio bug
    Oct 2004
    hdradio bug
    till having problems with my hdradio to work with CF i have all the way up too framework 3.0 on the macine and all that and still i can here cf turning it on and or off cuaes i here clicking when i push the radio button. but after that i cant control it at all and hear no static or anything??
    Jan 2008
    HDRadio volume extremely low with CF RC2
    Can you try cranking up the volume?
    RC2 seems to set the Directed HDRadio volume very low.
    I can hear it if I turn the volume way up.
    If I first let the normal Directed controller bring up the radio, and then plug the audio in to my sound card, the volume is fine.
    Oct 2004
    my problem is that cf is not controling the HDRADIO at all if i click tune up or tuen down the numbers do not move... that and for some reason cf will not unmute the line in. i go and unmute it manualy but if i exit the hdradio go back to my playlist then go back into hdradio line in is muted again so its CF that is muting the line in.
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by nadforever View Post
    check your settings, if you turn off buffer it will not mute your playback line, if you want to use buffer make sure to set the recording input and it should mute playback line so it will record and playback through the recorded file on the system...
    not sure why not controlling system, try hard coding the COM port...
    "C:\Documents and Settings\David\Local Settings\Application Data\Centrafuse\RadioModules\HDRadio\HDRadio.xml"
    you can set volume levels and COM port in this file and restart Centrafuse...
    david
    Oct 2004
    i already have gone to the XML and changed it to the correct com port and still dead in the water, i heard disabling will stop the muting of the line in. havnt been able to test that part of it yet though. not shure what else could be the problem when the standalone app for hdradio works fine but in centrafuse cant get anything..
    Jan 2008
    Exclamation HDRadio.xml file not there
    Such a path does not exist on my XP SP2 machine.
    I do not have a login.
    The 'Administrator' has no "Local Settings" directory.
    PLEASE move this config data to a central place.
    These are Car PCs, not general-use PCs.
    No need for individual users!!
    Quote Originally Posted by golffnut View Post
    these are rules, you have to store files you can write into LocalAppData, or they will not run on Vista...
    replace /David/ with the name of the user you have logged in with, and make sure show hidden files is visible...
    we have removed most all cases where you need to go here, only a couple things left...
    david
    Oct 2004
    back when i had rc2 i had radiomodules and a HDradio folder now when i go to radiomodules there is no HDradio folder.
    MySQL Error
    Oct 2004
    C:\Program Files\Flux Media\Centrafuse\RadioModules\HDRadio
    thats where the module is for me, always has been on 2.x
    the config files are right in the the RIGHT place too!
    also, HDradio works quite good in RC3, there are a few little things to clean up
    but its basicly there
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Oct 2004
    i dont believe anywhere in eaither of them has an area to tell it what com port u are using. te original was and XML file
  1. Gesture based bug recorder/tracker
    By Iceman_jkh in forum Road Runner
    Last Post: 12-25-2007, 10:28 PM
  2. StreetDeck Bug Reporting System
    By RedGTiVR6 in forum StreetDeck
    Last Post: 12-10-2007, 03:07 PM
  3. Bug Tracking (sorry long but please read)
    By liquid_smoke in forum Software & Software Development
    Last Post: 04-22-2005, 04:12 PM
  4. RR 2-20-05 ... Bug Fixes ...
    By guino in forum Road Runner
    Last Post: 03-01-2005, 02:27 AM
