hmmm, everything is getting called that should be. I assume that CF unmutes the line-in when you open
radio? Looks like it does from the log. Which means your radio must be failing to turn on or output audio. Strange, and like I said Infill radio is reported working from many sources. What I can do at least is add more logging so that when RC4 is released we might be able to tell more what is happening...
Do you still have the streetdeck installed on it? Does your radio work when running SD? Did your radio ever work running SD?
