anychance you can send me the config.xml file as I can't get this to work, no matter what I try...
It just will not embed D3 at all!
John
Once I figured out to point at the EXE rather than at the shortcut (DUH!), no dramas embedding GPS in Centrafuse.
BUG: If I open Dest3, then close Dest 3, and attempt to restart Dest 3 without restarting Centrafuse, then Dest won't start again.
Once I exit and restart Centrafuse, all is OK again.
While we're looking at the GPS screen, can we work some simple noise controls into that screen? It's nice to kill the noise when you're frantically navigating through an unfamiliar patch of town.
Have a screen shot!
C!
http://carpc.riposte.net
I reserve all rights in connection to each post I author, without exception.
John
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
C4M: If you just click the title bar and get out of fullscreen mode you have all the noise controls...
I made the assumption that you would generally only load GPS once and then always leave it open... Why would you close D3 once it was embedded? My app will close it out for you when you close CENTRAFUSE and it doesn't use much more memory... Currently it just runs the app the first time you click it, but I will add a check to see if its running and re-load if its not there..
david
I thought about that after I made the post, and realised that it stays open in the background, and you make a good point. Now that I understand that, it would be redundant to close NMDest!Originally Posted by veetid
I guess the check and re-load is more an idiot-proofing thing.
C!
You realise that there is a thread for this specific issue? Your issue isn't related to this thread.Originally Posted by Tuned Vitesse
C!Code:<GPSPATH>C:\DestinatorApps\Frontend_PREV\Destinator3.exe</GPSPATH> <GPSWINDOWNAME>Destinator 3 - [Dest3.1]</GPSWINDOWNAME>
When I exit centrafuse destinator will remain open!!!
Is there something I am doing wrong?
There is a problem some times.... CF suddenly closes MapMonkey!!!
Is this a common bug??
