Results 1 to 6 of 6
Thread: Hibernation and Dim modes
    VENDOR - Centrafuse veetid's Avatar
    When you resume from hibernation or standy, CENTRAFUSE is suppose to re-apply the current dim mode. For example if you dim it all the way and hibernate, it should be dimmed all the way when you come out of hibernation.
    This works on my desktop and laptop, but just noticed it not working on my carPC. Is anyone else experiencing this problem?
    david
    Jun 2005
    NJ
    After Hibernating the car PC with Centrafuse running I noticed that when I resumed windows and exited Centrafuse Windows took on the same Gamma properties. I changed the gamma back to defalt but every time I would start up Centrafuse the gamma would darken. I tested it on my laptop and did not get the same results.
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    BTW does it work by setting system contrast values or did i just imagined??
    cause i think i somehow managed to exit CF so that dimming stayed on... i found that rather unwanted behavior!! but it might be that i have just eaten too many mushrooms...
    Low Bitrate Bokky's Avatar
    Jan 2005
    Ham, Belgium
    I use it all th time on my CarPC without any problems. Dimmed in and out hibernation without changes...
    All works fine on my system..
    Maybe as future feature that you can also set day and night times for auto-dimming! That would help me a lot...
    EPIA M10K, 512MB RAM, 60GB
    [##########] 100% (since 1 March 2005)
    snowboarding.be - bokky.com
    Jul 2005
    Funland
    Quote Originally Posted by Bokky
    In that case times would have to be dynamic depending time of the year. (atleast when gps tells that car is near polar regions)
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    It seems that windows does adopt the gamma setting.
    Say that I do not have it in the startup folder, and run it, then something happens and I have to restart from a crash etc ... well CF doesn't start up, but the gamma setting are the same.
    I like having it "keep" the setting, good call David..
    Don
