I'm curious what the middle of the url is ??
thats the part without the " ... "
Our traffic information url is (note the possibility to set screen height and width, very nice) :
http://mobil.vv.se/mapviewer.aspx?cm...=400&scr_w=500
But, if I enter that URL in the settings I get an "error in config" error message and it won't accept it.
If I manually enter the URL in the XLM-config file, it forces Centrafuse into setup mode on next lanuch.
If I enter the short URL, http://mobil.vv.se, it accepts it, but then clicking on the "TRAFFIC" button all I get is a "Action Canceled" message from IE.
If I would enter either of thease URLs in the webbrowser of centrafuse, then it works just fine.
/M
how about using just
http://mobil.vv.se/mapviewer.aspx?cm...=113&object=1&
It's because of the &. That is an invalid character in XML... Try replacing with & or #&160; I think... I don't remember the code for it...
david
Well, ampersand kinda did the trick, it's now accepted as an URL.Originally Posted by veetid
But do you read the xml file as xml or as plain text ?
Reason for asking is that & is not converted into & as I thought it would be when you read an xml-file, the link therefor contains "&" as well and doesn't resize properly.
No, the whole point with the long URL is that you can set the screensize and get the window the size you want it to be, meaning that you'd get rid of the ugly scrollbars.Originally Posted by Don 944 LA
/M
Maximus: It is parsed as an XML DOM. & is an html encode type, so I can see how it wouldn't parse out to a &. There should be a character you can enter that the XML dom will evaluate as &, not sure what it is though...
david
& is the code for xml as well, must be something wrong with the way it's parsed.
[H]4 Life
I'm a lesbian too.
I am for hire!
also try this:
Ok this won't print right on screen so I'll type it.
"ampersand pound 38 semicolon pound 38 semicolon"
[H]4 Life
I'm a lesbian too.
I am for hire!
Odd,
..............zoom_region"ampersand pound 38 semicolon pound 38 semicolon"area=113.............. in the config file (I put it the correctly, but it wont display properly in the forum)
turns into ..............zoom_region&area=113........ ..... in the url
.............zoom_region&area=113............. .. stays the same.
/M
