Results 1 to 7 of 7
Thread: cd player not playing
    Maximum Bitrate neon_eddy's Avatar
    Nov 2004
    Coon Rapids, MN
    CD player ..
    I have a CD-ROM mounted in my dash for playing cd's .. connected via Fire-wire .. ripping works great, however if I try and play the cd it won't.. it reads the tracks.. and loads them up .. it won't play it.. it sees the length of the track.. but it never starts "0:01, 0:02 ...." .. ect ..
    it plays fine via windows media player.. I'm not using the cd audio line.. just data
    but again, great software..
    Shawn
    I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
    Check out my web company Minneapolis Web Designer - Himmelberger Design
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    do you have the device options in media player set like this? (i am guessing as i dont have any front-end installed yet)
    Nov 2004
    Coon Rapids, MN
    I'll give it a shot..
    but it WORKS via media player.. so I'm thinking yes.. but I'll look.. thanks for the advice..
    Shawn
    Mar 2004
    Bristol
    Does Cf use media player or winamp?
    eDIT: jsut did a quick and it would appear to use directsound not a mediaplayer like some of the other apps. Maybe it is in your general device settings somewhere. I am sure some CF expert will notice this thread soon if i keep making crappy suggestions and keep it at the top of the recent threads list!
    Nov 2004
    Coon Rapids, MN
    last I heard he said he used directX .. it doesn't do a winamp type install like MediaEngine did .. at least that I can tell.. I'm gonna go and take a look at it right now.. i'm do for a "break" .. anyway ..
    seriosuly I check the forums here about once every 10 minutes..
    Shawn
    VENDOR - Centrafuse veetid's Avatar
    I haven't ever experienced this problem and I also play CD's regularly. Does it do it with all your CD's? Try to disable AutoPlay CD, load a CD in the drive, go into music manager and click Play CD. This will take a second because it will check to see if you have an internet connection and if so it will get the CDDB track/artist/album information. Otherwise it will just label them Track1, Track2, etc... Then it should start playing your track. Which OS are you using? I actually use WMI to play CD's.
    david
    Newbie AndyXR's Avatar
    Feb 2005
    Slovenia
    I have exactly the same problem. It plays in mediaplayer but not in centrafuse. This is on XP and the CD is connected via IDE.
    Epia M-800
    160GB HDD
    256MB RAM
    Slim DVD
    Morex Case, M1-ATX
    GPS Mouse
    Bluetooth
    WiFi
    OBD II
    Liliput 7" Touch
  1. HU w/o cd player?
    By thrice in forum Car Audio
    Last Post: 03-22-2005, 01:45 AM
  2. FS. CD changer, DVD player $50
    By jimmythecow in forum Classified Archive
    Last Post: 02-26-2005, 10:01 AM
  3. simple CD player
    By OrionManMatt in forum Car Audio
    Last Post: 09-19-2004, 02:58 PM
  4. Standby while playing cd on firewire cd player
    By psyclobe in forum Media Engine
    Last Post: 06-03-2004, 12:10 AM
  5. aiwa cd mp3 player
    By djjazzy in forum General Hardware Discussion
    Last Post: 08-29-2000, 11:36 AM
