Results 1 to 10 of 11
Thread: Duration of MP3 Incorrect
    Feb 2005
    When I start playing an MP3 that has a long duration, such as live mix sets, I've noticed that the displayed duration of the MP3 is not correct. For example, an MP3 file could be a 112 minute file but centrafuse displays that it is only 2 minutes long. The whole file plays and the play counter is correct. The only thing that is off is the total duration of the MP3.
    Maximum Bitrate dodgetimes2's Avatar
    MI
    I've also noticed this with some VBR mp3s. CBR's seem to always work perfect though.
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Same problem. I get some 14 minute songs
    Denmark
    Same here... all in all there's several problemes with the MP3 playback, also some of my mp3's won't play at all, even though they play perfect in winamp.
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    blame that on windows cuz this also show up when using media player. personally, it doesnt bother me. if it is a major problem, just re-encode to cbr.
    Your everyday carpc geek and tech guru at your service. *bow*
    VENDOR - Centrafuse veetid's Avatar
    you could try changing your mp3 decoder, that might fix it... I have never had a problem with my mp3's, but I encoded most of them myself and I know they are proper... I have seen some files not play, usually files from P2P programs and they are invalid... The reason they play in winamp is because winamp will actually play bad mp3's... I plan on researching what all winamp does to play non-valid mp3's... One thing I know they do is scan the whole file for the header information instead of the beginning of the file, where it is suppose to be...
    david
    Feb 2005
    The file length and play duration show up correctly in WMP...
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Might be a codec issue. Do you have any of the codec packs installed? If so, try uninstalling them and see if the problem still persists..
    Variable Bitrate silencery's Avatar
    Jul 2004
    Los Angeles, CA
    I've got this issue too. A bulk of my collection has been re-ripped and encoded in 192VBR.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    same problem on a clean winxp installation
    only xp rivers and cf
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  1. Commerical MP3 Hardware
    By MooN in forum General Hardware Discussion
    Last Post: 09-26-2005, 05:22 AM
  2. MP3 goes 5.1
    By camsgs3 in forum Software & Software Development
    Last Post: 01-14-2005, 05:43 PM
  3. MP3 costs
    By mp3designer in forum General Hardware Discussion
    Last Post: 01-29-2001, 01:18 PM
  4. Car MP3 Costs???
    By mp3designer in forum General MP3Car Discussion
    Last Post: 01-24-2001, 11:45 PM
  5. Do you guyz know this cool machine?
    By Ginger in forum General Hardware Discussion
    Last Post: 04-19-2000, 12:38 PM
