Results 1 to 10 of 10
Thread: multiple drives for music path?
    I have my C drive and also a usb drive and would like to include music from each in the library. It appears that only one drive can be accepted for the path. How can I include both drives in the library?
    thanks
    glenn
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I hope david will include this feature, maybe configuring multiple roots (eg DVD-ROM, HDD1, USB ecc)
    EDITT
    by the way you could map your USB device partition under a NTFS folder using disk administrator, I never did it but I know it is possible
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    could someone walk me through the above mentioned process?
    Nov 2004
    Italy
    Well I use xp in italian, by the way the function should be under Administrative Tools, computer management, disk management (I guess).
    here you see a list of all the disks (removable or not). plug your usb storage and under disk management you'll find it, right mouse click on the disk and select "remove/add drive letter" or somthing like this; here you'll find "map under NTFS folder". simply create a new folder and the drive into it, it should work. remember that my indication may be wrong, i don't use windows in english
    hope it helps
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Trouble with that is, you may have to do that each time you insert the USB stick.
    That's what seemed to happen when I just tried it.
    Nov 2004
    Italy
    not for me
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    I tried those steps and it would not let me check the ntfs file option. sounds like a solution though. any ideas?
    just figured it out-need to hit "add" in the screen prior to the assignment screen
    Nov 2004
    Italy
    you can choose ntfs folder only if the partition is not write protected, e.g. a CD cannot be mounted on a ntfs folder, but my usb stick works
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
    i have an 80 gb laptop drive in an externalcase. I mapped it through an ntfs folder in my C drive, then listed the C drive in the music path in settings. the CF did not pick up the songs on the external drive.
    Nov 2004
    Italy
    I admit I never tried with CF, I'll try asap
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  1. Multiple CD/DVD drives ??? << Newbie!!
    By dashusa.com in forum Media Engine
    Last Post: 01-07-2005, 12:27 PM
  2. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  3. FS: 704MB IDE Solid State Drives
    By dj2fast in forum Classified Archive
    Last Post: 05-09-2004, 04:19 PM
  4. mpxf multiple playlist path
    By redscar in forum Software & Software Development
    Last Post: 08-17-2002, 03:03 PM
  5. Using WinAmp or other across multiple drives?
    By Tony S in forum Software & Software Development
    Last Post: 04-13-2001, 06:59 PM
