Got the following error when attempting to load one of my albums (occured when hitting LOAD button). So I close the app, and upon relaunching I get a huge long error (sorry, don't have it captured as it is in a dialog, not copy-able), and I cannot start the app. Only workaround was to delete the MAIN.DAT file which seems to force partial re-install of missing components when launching the app...
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at centrafuse.Music.visTick(Boolean forceupdate)
at centrafuse.Music.minivisTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
centrafuse
Assembly Version: 1.3.2021.30940
Win32 Version: 00001.00003.02021.30940
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/centrafuse.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
ReflectionCleaner
Assembly Version: 1.0.0.0
System.Data
CodeBase: file:///c:/windows/assembly/gac/system.data/1.0.5000.0__b77a5c561934e089/system.data.dll
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
cfplayback
Assembly Version: 2.1.0.5
Win32 Version: 2.1.0.5
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/cfplayback.DLL
Xheo.Licensing
Assembly Version: 2.1.5000.0
Win32 Version: 2.1.5000.26c
CodeBase: file:///c:/windows/assembly/gac/xheo.licensing/2.1.5000.0__798276055709c98a/xheo.licensing.dll
System.Web
Win32 Version: 1.1.4322.2037
CodeBase: file:///c:/windows/assembly/gac/system.web/1.0.5000.0__b03f5f7f11d50a3a/system.web.dll
System.Web.Services
CodeBase: file:///c:/windows/assembly/gac/system.web.services/1.0.5000.0__b03f5f7f11d50a3a/system.web.services.dll
Microsoft.DirectX.AudioVideoPlayback
Assembly Version: 1.0.2902.0
Win32 Version: 5.04.00.2904
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Microsoft.DirectX.AudioVideoPlayback.DLL
System.Management
CodeBase: file:///c:/windows/assembly/gac/system.management/1.0.5000.0__b03f5f7f11d50a3a/system.management.dll
Freedb
Assembly Version: 1.0.0.1
Win32 Version: 1.0.0.1
CodeBase: file:///P:/Program%20Files/Flux%20Media/Centrafuse/Freedb.DLL
RegexAssembly1_0
Assembly Version: 0.0.0.0
Win32 Version: n/a
CodeBase:
Microsoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dll
************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
