David specified that XP is required on his website. You make have to upgrade windows.
Both computers are running 2k. I tried the install first, then copied the folder and just replaced all the files on the carputer, with the ones from the desktop. Both comps have the same .net installed, so I'm still kinda lost as to what to do next.Originally Posted by tj!2k4
Agree 100% with that. I'm a big fan of wider playlist display area so you can fit more of the songname in the screen since I don't browse my songs by artist/albums like most people do.. I end up seeing only the band name and album then it gets cut off.. Even then it probably won't make it to the song name.. I should probably start making ID3 tags and such if I ever want to use most of the softwares that are made now beacuse they all have very little width for text..Originally Posted by krog
On a side note, if you click on the cover art image, it changes between 2 different graphic eq thingys..![]()
1991 Camaro Z28
2004 Acura TL
But it works just fine on one 2k machine and not on another.Originally Posted by spdyscotty
I don't know what to tell you. There could be an issue with some builds of 2k, that's why David requires XP. I'm at work right now and have it running on 2k myself. It seems to work fine, but I'm sure there's a reason xp is required.Originally Posted by OoNikFraleyoO
Ah well, it's not a big deal.. It's probably alot of work to just remove it from the screen with a click in the settings anyway.. Doesn't bother me all that much now since I was just informed that Centrafuse won't display the full band/album/track by filename anyway.. That's pretty cool what you mentioned though.Originally Posted by tj!2k4
1991 Camaro Z28
2004 Acura TL
Same version on both machine. Same disc even. I'm gonna just reformat the carputer and start over from scratch. I need to do that anyway. There has to be something that I'm missing.Originally Posted by spdyscotty
David, have you figures anything out to why this is happening? I did assign the drive letter....The CD problem... Make sure you have your CD letter specified in setup or it will not work...
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
not sure about this... I can't reproduce this problem.. CD's play fine.. Do you have autoplay enabled? Does anything happen when you insert a CD. What about when you insert a DVD? Try a data CD that contains some music files just to see...Originally Posted by Cheekz185
david
