It doesn't even attempt to access the CD drive, if that helps..
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
I have the same problem as Cheekz185... D: set as CD, but get the "no tracks present prompt".
DVD works fine. I am running XP SP2. If I click on disk from Windows desktop Media Player 10 opens and works fine. I have tried autoplay off and on,.... no joy.
This was also a problem in V1.2... changed to V1.3 hoping that it would be solved.
wow you got much on your hands already, here is another:
When you click play in the MEDIA, the status bar displays Pause, when it should be saying "Playing" ;if i confused u ask me to further explain.
Great new look,many things fixed compared to 1.2
DICE Los Angeles
I got the solution to CD player problem...
Heres whats causing it... In the screenshot I see the CD Letter setting says D:\ this is wrong... this should just say D It is only suppose to be the letter.. you will need to change it in the config.xml in the system folder...
the :\ is what is causing it to fail... That is a bug from my setup populating the wrong thing from the dialog.. I will get that fixed...
david
Hi David, your fix worked 100%! Thanks, it was driving me nuts.... gonna try rip a CD now...
By the way the CPU utilisation is far better on this version... runs a consistant 2-3% with no media playing. Ver 1.2 ran 35% in idle....
Nice work, I really love the simplicity of this program.... later.
Your everyday carpc geek and tech guru at your service. *bow*
Mine started doing the same all of a sudden. Its driving me crazy LOL!
I have AutoPlay set to OFF.
Originally Posted by camsgs3
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
ever since i installed it my A drive hase been going mad even if the program isnt running
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
I never found that floppy problem in 1.2... That narrows it down atleast.. I know it's in some of the code I pulled from 1.2... I have one computer that still has a floppy drive and it doesn't happen on that machine... I need to find a setup that causes the problem so I can debug...
The only code I have that queries windows for drive status is the autoplay... and some say it still happens when autoplay is disabled... What about if you disable autoplay and reboot... does it still do it when you come back up?
david
