no the minutes are not showing here either but it is with some peeps so maybe a time setting (like US and European :P?)Originally Posted by skydiver
that did it thanks
anyone mentioned the clock no mins
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
my destinator map resource down permanently
yes... I feel the clock problem has something do with localization...
david
just got netstumbler working in CF but have a prob.
works great first in fullscreen and small screen and i can switch between fine .
BUT when i start map monkey and go back to net stumbler i lose the switching i get the noise but nothing happens.
MM still switches fine.
maybe it is because netstubler uses windows within windows ?
also MM still runs after closing down CF
i observed similar behavior with FrodoSatRadX and iGuidance.
Once I launch FSRX, I can't switch between fullscreen/window mode for iGuidance; iG just stays in window mode (and CF beeps at me) when i click the titlebar to maximize it.
If there is no ID3v1, only v2 then you'll get something like this:
"Unknown Artist - Stevie Wonder - I just called to say I love you"
Edit the tag to be the same in both v1&v2 and rebuild and it works ok..
Same thing if there is no tag at all.. Then it should just display the filename..
Not "Unknown Artist" + %filename%
Don't know if this has been covered.. Didn't feel an extreme urge to read through 11 pages..
So if it has already been reported, I second that...
/p
A really small one here:
If you have a song that contains a ' in the tag it will be "doubled"..
I.e. Tag = "Hard to say I'm sorry" shows as "Hard to say I''m sorry"
/p
Originally Posted by paran0id
David,
You had said something about getting a program called "THe GoDFather" I Downloaded it but I do not understand how to use it. How do you use it to put tags on all your mp3's.
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Seems to have stopped for me after rebooting.
I wonder if there is 'something' that triggers this all of a sudden. I'm not convinced it will have stopped forever now.
Originally Posted by veetid
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
