You are holding it down too long... If you hold it for 2-3 seconds it will set that number with the current station... If you hold it down for 4-5 seconds it will let you rename your preset...Originally Posted by skydiver
david
David,
ANy reason why System Tools does not show anything?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
david
Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall returnThe car
got it thanksOriginally Posted by veetid
David,
I am having some problems with Radio and radiator. Radiator works fine, but when i enter radio in cf it shows a .net error. I will try and narrow it down a bit more.
David
Just wanted to let you know that the mixer doesn't work on my Epia SP13000.
The rear/sub channels are stuck at the bottom and don't control the sound output properly. Also, I don't know if you'll remember, but I was asking in another thread about mixer presets, and you told me that 1.3 had them. I think you got confused with EQ presets and mixer presets. I see the EQ presets, however I'd love to see MIXER presets as well if at all possible. I listen to live music recordings sometimes and the levels require different output settings to my subs/in car speakers.
Mark
1997 Acura 1.6 EL
Ampie Case, Epia SP13000, 1G ram, 80g 2.5" HDD, Tripnav GPS, Lilliput 7" Touchscreen, M1-ATX
I know you are trying to get a bug release version to cover all the current bugs, but is it possible to get the track not advancing fix but out nowDavid: I fixed the track not advancing bug... The event was gone... I must have accidently removed it when I was cleaning up the code for release... It was late. Thanks.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
And I was about to ask about that above problem too :-P
I don't think this one has been put up yet..
So I just decked out all my MP3 folders with album art (hadn't done that previously). In CF, if I go to the playlist editor and browse by Album, if I scroll down to the end of the albums, I get a .NET error saying 'Out of Memory'. Task Manager shows CF using about 70Mb, and I have 512Mb in there, so I know i'm not actually out of memory.
If I click continue, I can no longer browse any part of the playlist editor except what's in the current queue. Otherwise, it closes CF if I hit Quit.
im not sure is this has been up already but..
when i hold the mouse clicked down over the playlist.. this happens
