Page 19 of 34 FirstFirst ... 91011121314151617181920212223242526272829 ... LastLast
Results 181 to 190 of 331
Thread: Centrafuse 1.3 Bugs
  1. #181
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Jahntassa
    I don't think this one has been put up yet..
    So I just decked out all my MP3 folders with album art (hadn't done that previously). In CF, if I go to the playlist editor and browse by Album, if I scroll down to the end of the albums, I get a .NET error saying 'Out of Memory'. Task Manager shows CF using about 70Mb, and I have 512Mb in there, so I know i'm not actually out of memory.
    If I click continue, I can no longer browse any part of the playlist editor except what's in the current queue. Otherwise, it closes CF if I hit Quit.
    Does it happen in the same place every time? How many albums is it?
    david
  2. #182
    normal install, BEFORE any xml based modification
    bug1 ---------------> can not show the full clock by default font
    bug2 ---------------> the internet connect/disconnect do not work
    good designs !!!!
    on:
    1.CF get forcus and change to top display each new media started
  3. #183
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by veetid
    david
    here it is doing the same thing in the media manager
    and yeah its all cd's that i have tried..
  4. #184
    bug3 ---------------->each time exitting CF1.3 error report
    the memory can not be read
    BTW, where shall I send the main language file of SPChinese?
  5. #185
    you can post that language file in the languages sticky, or email it to my support address on the website...
    I was checking the functionality of the connect/disconnect button... It did have a display problem, which I fixed..
    for those who couldn't get it working remember that it only dials/hangs up your default internet connection. So you need to go to internet options/connections/highlight your connection/choose Dial whenever a network connection is not present/set default
    this will give centrafuse the control over the internet connection.. It will display disconnect when it detects an internet connection and will hangup the connection if clicked (or do nothing if on LAN)... It it will display connect when there is no internet connection and will dial the default internet connection when clicked (if no default internet connection is set it will do nothing)
    david
  6. #186
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Quote Originally Posted by djmickyg
    http://www.mp3car.com/vbulletin/show...2&postcount=45
    rickster, add that to your 1st post about the bug workarounds..
  7. #187
    Feb 2004
    Quote Originally Posted by tj!2k4
    that worked.. but what is that huge letter that comes up when u do hold the buttin down??? i get al sorts of random letters poping up? it dont make sence
    also another problem i have is after a song is finshed the new one doesnt start?? even thought i have a whole cd loaded into my list.. what the?
    also i think this has come up.. all my folders have album art but they dont show up.. only a few do.. there all called album.jpg
  8. #188
    Aug 2004
    One bug, that i don't think have been posted here is this:
    When I browse the music in Media Manager, select a song, hit + and Load, it loads all the files in that folder into the playlist, and removes the files who where there before..
    If i do the same, but press queue BEFORE pressing Load, it loads only that file in the existing playlist, like in 1.2..
    This happens if I select one og more files..
    Also i would like to say that IMO, singelclick and removing the "Song added to playlist" dialog, would be great.. Singelclick is the beste while driving, so you don't miss all the time..
  9. #189
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    Thanks mate. 1st post updates.
  10. #190
    Aug 2004
    More bugs to add to your collection!!!
    David, BTW...Great program...
    Now on to the bugs... I've tested it on 3 different computers... Map monkey embeds into Centrafuse on 2 of the 3 computers (and guess what...my carputer is the one that doesn't work)... First I got the error that MapMonkey crashed every time I tried loading it and I think it was some file that was corrupt or shared by the old Centrafuse which I uninstalled before installing the new one... Well to fix the errors I reinstalled Map monkey and it loads up correctly...
    Ok Map monkey starts up fine but doesn't embed into Centrafuse like IGuidance does. It comes up as a separate screen (yes I did correctly name the window to the exact name as the program window) the other 2 computers worked fine... (Double checked all the system .XML files and copied and used the ones that worked from the other computers and still same results.
    Ok this is what I need to continue testing... all 3 computers run WinXP SP2 but not sure if they are all running the same updates and .Net service packs and so on... Will verify because I believe .NET installed version is critical to getting this installed correctly...
    BUG 2... Load up time needs to be quicker... Takes a lot longer to startup then the old version. I was able to get my carputer up and running from a complete boot in 1:20 exactly till I hear the music and now it takes longer (don't have the exact time since I haven't timed it yet)
    BUG 3/request... How do we remove that start up music... really was that necessary... Don't really like hearing the same startup music each time I start my car it's going to drive me nuts. plus I rather it play a random song in my play list....
    BUG 4... Song title at the top doesn't scroll.
    BUG 5 or maybe it's by design... I saw screen shots that while you had your music playing and had the Visualization in full window that there was a box at the left corner with the title of the music playing. Was that implemented or only on your next release? Very cool feature!
    One other request... How can I place the exit button on the menu or somewhere else so It's a quick one click exit from the program?
    Will keep you updated on the progress of the hotfix updates and release versions.
    Also can you please release updates and fixes by separately releasing files that needed to be updated instead of us having to do a complete reinstall each time an update comes out...( maybe have the updates like a feature pack or service pack install...)
    Thank you,
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. Bugs so far in 1.3 BETA
    By GReeToZ in forum Centrafuse
    Last Post: 07-17-2005, 09:00 PM
  4. preview centrafuse 1.3 ...
    By TheKingPlaza in forum Centrafuse
    Last Post: 06-19-2005, 05:59 PM
  5. Releasedate of Centrafuse 1.3
    By superbowl in forum Centrafuse
    Last Post: 06-15-2005, 02:19 AM
