Page 20 of 34 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 331
Thread: Centrafuse 1.3 Bugs
  1. #191
    SOS
    SOS is offline
    Jan 2005
    Video
    Did some more testing, video will not work on my carputer (works fine on my laptop, 1 display solution).
    When i startup up video there is no video in the thumbnail, just the standard "speaker" picture. The sound is there so the video is playing.
    If i setup with a 2 display solution, video will play on display2, but not full-screen.
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
  2. #192
    Variable Bitrate rickster's Avatar
    Feb 2005
    Essex, UK
    David,
    I changed my country formats under control panel -> regional settings from english(united kingdom) to english (united states) and now both the date and time display correctly.
  3. #193
    Feb 2005
    Essex, UK
    ok, did some more research into this time date problem. What i have found is:
    US locale settings Date:- m/d/yyyy (8 characters)
    UK locale settings Date:- dd/mm/yyyy (10 characters)
    US locale settings Time:- h:mm:ss
    UK locale settings Time:- HH:mm:ss (we display 24 hour clock)
    hope this info helps
    Edit: if i edit my uk locale to match the us locale, it does not work. Only if i select the us locale.
  4. #194
    FLAC djmickyg's Avatar
    Feb 2004
    Quote Originally Posted by Jokester
    David, BTW...Great program...
    Now on to the bugs... I've tested it on 3 different computers... Map monkey embeds into Centrafuse on 2 of the 3 computers (and guess what...my carputer is the one that doesn't work)... First I got the error that MapMonkey crashed every time I tried loading it and I think it was some file that was corrupt or shared by the old Centrafuse which I uninstalled before installing the new one... Well to fix the errors I reinstalled Map monkey and it loads up correctly...
    i had this same error with map monkey.. i found the solution..
    the window name for map monkey is to be
    destinator 3 - [gps]
    but... when it loads the first name that comes up is destinator 3 and then about 2 secs later the - [gps] bit comes up.. thats why centafuse doesnt regester the window as map monkey
    what i did with this is use the frodo player map monkey launcher..
    this is my mml.conf file
    DESTGPS
    mapmonkey.exe
    0,1755,12720,5445
    and this is what i have in my external.xml file
    <PATH>C:\DestinatorApps\Map Monkey\MapMonkeyLauncher.exe</PATH>
    <WINDOWNAME>DESTGPS</WINDOWNAME>
    <DISPLAYNAME>GPS</DISPLAYNAME>
    <PAUSEMUSIC>False</PAUSEMUSIC>
    <LINECONTROL>NONE</LINECONTROL>
    <STARTFULLSCREEN>true</STARTFULLSCREEN>
    now the window name is allways DESTGPS and its been working fine sice
  5. #195
    Feb 2005
    BUG 3/request... How do we remove that start up music... really was that necessary... Don't really like hearing the same startup music each time I start my car it's going to drive me nuts. plus I rather it play a random song in my play list....
    BUG 5 or maybe it's by design... I saw screen shots that while you had your music playing and had the Visualization in full window that there was a box at the left corner with the title of the music playing. Was that implemented or only on your next release? Very cool feature
    You could just replace intro.wav with a silent wave file to get rid of the startup sound.
    The visualization is activated by clicking on the album picture. It will cycle through two visualizations and back to album art.
  6. #196
    Aug 2004
    reply to Mbai2 & djmickyg
    guys thanks for all the help but that didn't work...
    djmickyg: if I run the mapmonkeylauncher.exe and configure it like you said it opens mapmonkey in a seperate window for some strange reason. embeds the mapmonkeylauncher without a problem but not the actual mapmonkey.exe.
    Mbai2: This is what I was talking about... doesn't seem to do this on our release.
    http://www.mp3car.com/vbulletin/atta...chmentid=14059
    Feb 2005
    Essex, UK
    Mbai2 is right. clicking on the thumbnail will change the visualisations. It doesn't work if you have 'always on top' set to yes in the settings screen though
  8. #198
    Jul 2005
    I believe Jokester is referring to not the visualization itself, but the song/album overlay that appears in the lower-left corner of the vis screen. I've yet to see it either and was wondering where it was. It might be due to the next-song bug (though it also doesn't work if you Alt-Shift-RArrow to skip a song while the vis is up).
  9. #199
    Feb 2005
    Essex, UK
    To confirm what we are talking about here, it is the track information in the bottom left corner of the vis. It is obviously a bug for some users then as i have it on mine. I will post a screen shot asap.
  10. #200
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I get the track info on my in-house system running a Matrox Triple-head Parhelia card. I do -not- see it using the embedded video (Intel I think) on my CarPC.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. Bugs so far in 1.3 BETA
    By GReeToZ in forum Centrafuse
    Last Post: 07-17-2005, 09:00 PM
  4. preview centrafuse 1.3 ...
    By TheKingPlaza in forum Centrafuse
    Last Post: 06-19-2005, 05:59 PM
  5. Releasedate of Centrafuse 1.3
    By superbowl in forum Centrafuse
    Last Post: 06-15-2005, 02:19 AM
