Page 21 of 34 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 331
Thread: Centrafuse 1.3 Bugs
  1. #201
    A-Z
    A-Z is offline
    Constant Bitrate A-Z's Avatar
    Feb 2005
    Atlanta, GA
    Get this error only in video mode whenever it trys to go to the next video. While audio i do not get this problem. Am i the only one?
  2. #202
    Quote Originally Posted by veetid
    I was checking the functionality of the connect/disconnect button... It did have a display problem, which I fixed..
    for those who couldn't get it working remember that it only dials/hangs up your default internet connection. So you need to go to internet options/connections/highlight your connection/choose Dial whenever a network connection is not present/set default
    this will give centrafuse the control over the internet connection.. It will display disconnect when it detects an internet connection and will hangup the connection if clicked (or do nothing if on LAN)... It it will display connect when there is no internet connection and will dial the default internet connection when clicked (if no default internet connection is set it will do nothing)
    david
    on CF1.2, it works,same machine....
  3. #203
    bug4 -----------------> then the number of songs selected on the playlist over xxx, CF refuse to play (press play button, nothing happens)
    I am testing the xxx, now confirmed smaller than 500
  4. #204
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    If I click on the vis button, and then click on the album art, it just goes back to the main screen, after doing this maybe 20 times last night, i finally noticed the vis had changed.
    2000 Sunfire build 100%, or is it ever really 100%?
  5. #205
    Raw Wave justintime's Avatar
    Apr 2005
    Clicking on SHIFT key on OSK will toggle rapidly
    If you go to the OSK and press the Shift Key (leave it depressed) then it will toggle between upper and lowercase at an insane speed. Same thing happens if you hold down the caps lock.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  6. #206
    Low Bitrate pastypyro's Avatar
    Nov 2004
    Austin, TX
    Will V1.31 be a patch we can simply apply or will it involve reinstalling and reconfiguring everything?
  7. #207
    VENDOR - Centrafuse veetid's Avatar
    this update will be a new install because I am changing the licensing... Lots of people had problems with the lic file... I am going to switch to using a serial number...
    david
  8. #208
    Apr 2005
    A little more investigation reveals that the white line only apears in cover art when using 800x480 (Xenarc native) resolution. I guess anything thats not exactly the same as 848x480 (skin's native resolution?) will show a vertical white line on the cover art. A little anoyying given the perfection and crispness of the skin!
    Quote Originally Posted by justintime
    I get a white line to the right of ALL cover art album images. The folder.jpg files do not have this white line, so it appears CF is putting it there?
    see attached image...
    2002 Honda CR-V
  9. #209
    Apr 2005
    david
    Will a new install use the exact same skin.xml file format? Sounds like you might be putting new xml tags in the skin file to enable some new features etc (as requested and as per feedback given). Starting to wonder how much work it might be to try to bring custom skin files up to date to be compatible with new versions (gulp!).
    Im not referring to the image files. I am talking about the skin xml file, to which I have done substantial (2-3 hours?) changes to work with new fonts etc.
    Im not complaining! I just think it might be good to bring this up now, before people spend too much time skinning (perhaps best to wait until final releases are out!)
    2002 Honda CR-V
  10. #210
    so far no structure changes have been made to the skin.xml.. if I there happens to be any I will put it in the release notes...
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. Bugs so far in 1.3 BETA
    By GReeToZ in forum Centrafuse
    Last Post: 07-17-2005, 09:00 PM
  4. preview centrafuse 1.3 ...
    By TheKingPlaza in forum Centrafuse
    Last Post: 06-19-2005, 05:59 PM
  5. Releasedate of Centrafuse 1.3
    By superbowl in forum Centrafuse
    Last Post: 06-15-2005, 02:19 AM
