Page 23 of 34 FirstFirst ... 131415161718192021222324252627282930313233 ... LastLast
Results 221 to 230 of 331
Thread: Centrafuse 1.3 Bugs
  1. #221
    Aug 2004
    Am I the onlyone having this problem??
    Quote Originally Posted by TommyTott
    One bug, that i don't think have been posted here is this:
    When I browse the music in Media Manager, select a song, hit + and Load, it loads all the files in that folder into the playlist, and removes the files who where there before..
    If i do the same, but press queue BEFORE pressing Load, it loads only that file in the existing playlist, like in 1.2..
    This happens if I select one og more files..
    Also i would like to say that IMO, singelclick and removing the "Song added to playlist" dialog, would be great.. Singelclick is the beste while driving, so you don't miss all the time..
  2. #222
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    I have a couple of problems with the OSK
    it works only the first time!
    1) if I open it again and digit some text it won't send the text at the application foreground, i tried this on two platforms with different applications
    2) if I select a text box already filled with text and then open the OSK the text in the textbox should be present in the OSK typing line, in order to modify
    e.g. in my gps application I digit the a wrong name, so I have to modify it but I can't, due to these two problems I just explained
    and by the way please swap "cancel" and "enter" buttons, they are definitely in the wrong place
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  3. #223
    Apr 2005
    Queens, New York
    Simple just dont press load. Just hit the "+" Then when you are done adding all the songs you want go to "Que" Then hit Load!
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  4. #224
    Nov 2004
    Italy
    my scenario...
    I'm listening to a playlist created in directory mode, I want to add other albums (in directory mode) so I go to the media manager and..?? It seems I can't add a song or an entire album without deleting the current playlist or making it restart from the beginning! I see, I'm doing something wrong I think.. but I tried several times with no luck, someone can point me the solution please?
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  5. #225
    VENDOR - Centrafuse veetid's Avatar
    if you are listening to an actual created playlist... when you go back into media manager and "+" another album, it is actually adding it to your queue and not the loaded playlist... The "+" always adds to the queue, unless you enable advanced manager.. If advanced manager is enabled and you have a playlist loaded... when you click "+" to add another album it will be automatically saved into your playlist... you then can hit playlists, highlight the playlist you are listening (should already be highlighted), and hit load... this will not restart your playlist...
    david
  6. #226
    Nov 2004
    Italy
    hum
    it's a strange way to manage playlists I think.. a lot of clicks to simply add a couple of songs.. don't get me wrong I think it should be revised, the 1.2 way was really better in my opinion. Don't know the others on this forum but I've never used playlists in cf, I only keep adding song and dirs to the current playlist and, if I want, I save it. why not use this approach?
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  7. #227
    Nov 2004
    Italy
    Quote Originally Posted by veetid
    david
    hum
    I read again your post, i'm not sure I understand
    I add a couple of dirs using media manager, I did not save the playlist, I select my dir and play LOAD. afer that you can refer to my previous post.. don't know if this explanation is useful, I'm trylig to understand how this media manager works
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  8. #228
    it does function like you suggested... When you browse to a directory and just hit "Load' that clears the queue and loads your selection up... The exact same as "play now" did in 1.2... So if you browse to a directory, hit load, it will start playing.. If you then click media manager, browse to another directory, hit "+" to add it to your queue, click "queue", then hit "load"... It will not restart your music and add the new directory to the end of the playlist... If you want to clear your queue and start over and build an entire new list of music to play... Simply either delete the queue, which will reset it, and go add to it using "+" as many times as you want... or you can browse directories and hit "load" to auto clear it and load the selection....
    david
  9. #229
    Jun 2002
    Virginia
    Nice work, David!
    Additional issue: The play/pause button alters volume. When playing MP3s, if I hit pause, playback pauses as it's supposed to. When I hit the button again to restart playing, the volume comes back much louder than it was when I first paused.
    By the way, I also have the problem with the constant floppy seek. It continues seeking the floppy even after I have exited CF. I must reboot to make it stop.
  10. #230
    Quote Originally Posted by kbreeden
    Nice work, David!
    I have already fixed the floppy problem and it will be in the 1.31 release coming soon...
    I can't re-create the play/pause altering the volume... don't really see how that's possible... can you reproduct it everytime? Is it only with a certain format?
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release CENTRAFUSE BETA 2 (1.3)
    Last Post: 08-01-2005, 04:13 AM
  3. Bugs so far in 1.3 BETA
    By GReeToZ in forum Centrafuse
    Last Post: 07-17-2005, 09:00 PM
  4. preview centrafuse 1.3 ...
    By TheKingPlaza in forum Centrafuse
    Last Post: 06-19-2005, 05:59 PM
  5. Releasedate of Centrafuse 1.3
    By superbowl in forum Centrafuse
    Last Post: 06-15-2005, 02:19 AM
