@lossol it was an attachment maybe got stripped? try a new address?
license must be .lic extension
#6 all apps must be setup in \%centrafuseroot%\system\external.xml
create a hotmail account and send it there
#3 is phoco don't know if this is functional... i dont use PhoCo so can't test it but assuming enabled in one of the XML files
Even though David said Destinator is fully supported and integrated into 1.3?
i see some of you are having probs with the date not fitting. I modified the skin.xml file to width of the date. here is mine
Code:<DATELBL> <X>125</X> <Y>56</Y> <WIDTH>110</WIDTH> <HEIGHT>15</HEIGHT> <FONTNAME>Xirod</FONTNAME> <FONTSIZE>8</FONTSIZE> <FONTSTYLE>Regular</FONTSTYLE> <FONTCOLOR>#001933</FONTCOLOR> <ALIGN>Left</ALIGN> </DATELBL> <MODELBL> <X>240</X> <Y>56</Y> <WIDTH>200</WIDTH> <HEIGHT>15</HEIGHT> <FONTNAME>Xirod</FONTNAME> <FONTSIZE>8</FONTSIZE> <FONTSTYLE>Regular</FONTSTYLE> <FONTCOLOR>#001933</FONTCOLOR> <ALIGN>Left</ALIGN> </MODELBL>
Some have it showing "Disconnect" and others "Connected"Originally Posted by anky1
atleast that is what they have posted.. It is probably not internet connection
nor phoco, or it just isn't working properly..
I myself have it showing "Disconnect", which would be a little wierd if it was
phoco as I have neither phoco nor a phoco compatible phone..
Edit: @rickster: That did it.. Thanks a bunch..
/p
no he said it was fully supported in 1.3 and would be integrated in 1.4Originally Posted by m00ie
no, what I mean was the "torn piece of paper" it is a phoco button not sure if it is implemented or if you have to have the app installed...Originally Posted by paran0id
edit:#3: Neither does the green button in the low right corner.. Looks like a torn piece of paper
disconnect is its status. I believe it is phoco. Just like in 1.2. But now it is a button. I don't know why some have it saying connected thoughOriginally Posted by paran0id
