Post your bugs for the new release of Centrafuse 1.3 here.
Only post bugs - not requests
Some of the bugs have been fixed below.
#1. Your licence file gets emailed as an attachment. It should be emailaddress@domain.com_centrafuse.lic - If you did not receive it, check to make sure it was not stripped off with a virus/spam scanner
#2. GPS is not integrated in 1.3 - to use gps set up the software in the external.xml file. Example thanks to StevieG:
#3. The torn paper icon in the corner is actually voice control. If you have Sapi set up then this will activate/deactivate voice controlCode:<APP1>
<PATH>C:\DestinatorApps\Map Monkey\MapMonkey.exe</PATH>
<WINDOWNAME>Map Monkey - [GPS]</WINDOWNAME>
<DISPLAYNAME>GPS</DISPLAYNAME>
<PAUSEMUSIC>False</PAUSEMUSIC>
<LINECONTROL>NONE</LINECONTROL>
<STARTFULLSCREEN>False</STARTFULLSCREEN>
</APP1>
#4. to watch a movie on the second screen, add the movie to your queue and press play. then click the thumbnail and it will play on the second screen
#5. If any of the cf system files are deleted/corrupt the installer automatically runs when you click centrafuse.exe and they are installed again automatically
#6: Here is the problem with the CD not reading:
#7. This is how to save radio stations. Thanks to cheekz185.Quote:
Heres whats causing it... In the screenshot I see the CD Letter setting says D:\ this is wrong... this should just say D It is only suppose to be the letter.. you will need to change it in the config.xml in the system folder...
the :\ is what is causing it to fail... That is a bug from my setup populating the wrong thing from the dialog.. I will get that fixed...
#8. This is the fix for the font errors:Quote:
Click the numbers for your radio statiom for example : 97.10 Then click on tune.
When the station is displayed up top click the preset and hold it for 3 seconds and it will save it. But if you hold it for 5 seconds it will come up with the OSK and ask for the station name. You can name it hot 97 ect...whatever the namve of the radio station is.
Thanks to StevieG - there is a skin that is in creation. You can get it hereQuote:
I replaced the font at the last minute and didn't realize it didn't support bold and when you hold down the listview it takes the mainpanel font from the page and trys to bold it... I will get this fixed... for now you can replace 'GE Drover' in your skin.xml with a font that supports bold
Warning: If you are browsing the media directories and you click the remove icon (to remove something from your playlist) you will infact delete the file off of your computer. Make sure you only use the "-" button in the queues.
