This doesn't answer your question but I would appreciate a link to the PC version of Tele Type, or some screen shots of it running in CF.
I've checked their website and can't find a PC vresion - only PDA.
Thank you.
This was a problem in 1.2 as well.
I have imbedded TeleType GPS Pro into 1.3 and it otherwise runs very well. However when I have this loaded and on-screen, the GPS app originally has the UI focus (e.g. the pull-down menus are active and the app works great.) If I click 'next' or 'previous' in the Centrafuse UI to change the current song, the GPS app loses focus (menus get greyed out) and TeleType doesn't render itself unless it has app focus. This requires tapping somewhere within the GPS app's own window area to re-select it, then it works again until the next time I change songs.
Thank you.
I will look into making embedded apps keep the focus..
david
Two new bugs:
1. When speech recognition is enabled, it plays what the microphone hears through the speakers no matter what the mixer setting is. This immediately goes away ONLY when you disable speech altogether in the settings menu.
2. When embedding certain programs (I can only remember FSRX), CF will starting using 100% CPU and become slow.
You shouldn't hear what is said in the microphone unless you have the mic playback channel unmuted... I do not unmute it in Centrafuse...Originally Posted by Mbai2
What is FSRX?
david
It is muted in the mixer playback settings. However, when CF starts up, it unmutes but for some reason it still shows muted in the mixer. Once I disabled speech in the settings menu, it immediately stopped feeding the mic through the speakers.Originally Posted by veetid
FSRX: FrodoSatelliteRadioX
Crap, I just realized I put this in the wrong thread...I'll repost it in the bugs thread.
