i dont think it has any weird permissions, but then again, im somewhat noobish and aint sure what to look for in that regard...Originally Posted by veetid
and yes, the dvd plays in WMP on my carputer just fine, just not in CF.
The clickable area on the top title bar is too small ('rectangle' is too few pixels high).
On a touchscreen it is kinda hard to hit the 'spot'. Is there a way to make the clickable area taller? It appears to me that it is only accepting clicks within the Text's height definition. Which is a tad small for a click!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Originally Posted by justintime
the dimensions in "SKIN/SCREENS/MUSIC/VISUALIZATION" do control the vis... I just tested and the vis does fill the specified size... This is the same thing that happens when you run other resolutions... I did notice the vis isn't being brought to the front... so if part of the vis size goes behind the listview you will not be able to see it...
also note that the coordinates are relative inside that media section, not the entire page....
david
I'm running windows XP SP1. I get the error running CF 1.4 on one of my desktop computers. CF 1.3 ran fine without issues. Installed it on my other desktop and that one worked fine. Installed it on my carputer and it got a different error past the registration, but i fixed that by uninstalling cf 1.3 and 1.4 and reinstalling 1.4.Originally Posted by veetid
I've reinstalled .net thinking that was the issue but i still get the error.
Any suggestions?
Hrmmm I have to disagree. Are the bars in the visualization meant to scale up/down accordingly?
Try some ridiculous size like 20x20 and you will see that the bars remain the same size as in 100x100.
2002 Honda CR-V
yea the pics where on the 1st page of this post.....cool, i must have missed that info.....is ther a patch out for itOriginally Posted by veetid
still working on it...Originally Posted by camsgs3
david
I see what you mean... The vis does fill the screen, but it doesn't change based on the size really... it does, but not like it should... if you make that really large you will see that the right hand side pretty much does nothing... I will look into changing this up...Originally Posted by justintime
david
I'm just anal that way. Little details don't escape me
2002 Honda CR-V
david, please see post #92. thanx
