im in the same boat here. no dvd playback whatsoever. ill try loading up an instance of xp in vmware and see if anything changes there.
currently I'm out of ideas... reinstall windows maybe? sorry...Originally Posted by Tim97rs
david
Your everyday carpc geek and tech guru at your service. *bow*
I reported this one back in 1.3, but it seems did not get fixed.
If you hit your SHIFT key while in OSK (hit shift on your real keyboard and leave it pressed) you will see that the OSK will alternate rapidly between upper and lower case.
Same effect with the CAPS key.
Not a real problem unless you are using a real keyboard, but still...!
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
Ok. I hope you can add the APE tag support in a future version. Thanks.Originally Posted by veetid
Tim
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
Get a program called The Godfather. It ROCKS!Originally Posted by lifeboat
2002 Honda CR-V
David: first off great job.![]()
I've notice a bug that has not been mentioned.
If a song is playing and the system is placed into hybernation (have not tested standby) when the system resumes from hybernation and the song starts playing there is a clicking sound. If I pause and then unpause the song after system resumes from hybernation then the clicking goes away. If I pause the song before the system is placed into hybernation then there is no problem when the system resumes.
Also for a feature: When browsing the media library can the up and down buttons perform like the volume buttons. When you hold them down they will continue scrolling. Thanks.
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
When using voice, the "play" voice command does not work. I've tried changing the phrase assigned to play but nothing works. I can pause without problems though.
maybe this should NOT be called a bug, but in V1.3, it works good, in V1.4 it disappeared....
the CD selection on the media maneger.
I know when my songs crossfade into each other, the song playing stops well before the end (15-20 sec) of the song and just goes into the next. I think this is a known bug tho.
2000 Sunfire build 100%, or is it ever really 100%?
veetid:
Hey, I had this problem on 1.3 also, but was hoping for an automatic fix, but 1.4 has the same problem (both original and other skin).
When I wake up from hibernate in CF (where it was left off) the screen is just blank. Nothing wrong with the hardware, because I see the boot process, it just when the OS is up and CF takes over the screen blanks. The music plays in the background, I can use the touch feature of the screen and skip forward (because I know where the buttons are). Some times after 5 minutes and some times after 30 minutes or more the screen wakes up. I also tried pushing stuff to see if I could make it work, but havent found a good combination.
Im running on a Epia V10000 board with and NVidia PCI board as the primary board....
What kind of debugging can I do to help you find this "bug"?
/SOS/
XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
