Page 14 of 28 FirstFirst ... 456789101112131415161718192021222324 ... LastLast
Results 131 to 140 of 271
Thread: Centrafuse 1.4 Bugs
  1. #131
    Raw Wave justintime's Avatar
    Apr 2005
    Hibernation issues
    Don't know if this has been reported, but if I hibernate while playing music (mp3 files), when I wake up from hibernation the music continues playing where it left off, but the sound is all jumpy and jittery for the first several seconds.
    In one instance, the only way to resolve the problem was to PAUSE and UNPAUSE... then everything was normal.
    Is it just me?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #132
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by inniss777
    David: first off great job.
    I've notice a bug that has not been mentioned.
    If a song is playing and the system is placed into hybernation (have not tested standby) when the system resumes from hybernation and the song starts playing there is a clicking sound. If I pause and then unpause the song after system resumes from hybernation then the clicking goes away. If I pause the song before the system is placed into hybernation then there is no problem when the system resumes.
    Also for a feature: When browsing the media library can the up and down buttons perform like the volume buttons. When you hold them down they will continue scrolling. Thanks.
    What is up with this issue?
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  3. #133
    SOS
    SOS is offline
    Jan 2005
    Quote Originally Posted by veetid
    that is very weird... Are you using an LCD? are you hibernating in radio mode?david
    Lilliput 7", donīt even use the radio function (carpc is routed through a Pioneer system with radio).
    Funny thing is this failed EVERYTIME, yesterday i changed back to Blue ICE WS and then back again to Brushed Metal skin, and now everything works fine..... I will test it again with Blue ICE when I drive home tonight.
    /SOS/
    XP Pro, CF 2.0-newest| Pioneer HU with 7" flip-out (EQ, Surround)
    Epia V10000 + nVidia FX5200, Opus 150w, 7" Lilliput, DVD* SlotIn, Wavelan, Bluetooth, GPS, WebCams, DVB-T
  4. #134
    Jul 2005
    Sweden
    Don't know if this has been mentioned..
    While watching some music vids, the 'repeat' mode repeats only one vid all the time
    and not repeating the queue as I believe it should work.. Or shouldn't it?
    /p
  5. #135
    Feb 2005
    Quote Originally Posted by paran0id
    /p
    Repeat mode is supposed to only repeat one entry in the queue. THe queue itself will always be repeated.
  6. #136
    Jul 2005
    Sweden
    Then the repeat isn't working as it is supposed to with mp3's..
    I've had repeat activated since install and been listening
    to quite alot of music while fiddling with CF..
    Just tried it again.. Skips to next song as I believe it should with music
    Turned of repeat and it works exactly the same..
    Thus, repeat has NO function for music.. :P
  7. #137
    Feb 2005
    You're right! I guess I was just going by the assumption that repeat works like it did in 1.3.
  8. #138
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Quote Originally Posted by justintime
    Is it just me?
    No, it's not you. And I don't know if there's anything he can do about it, either. Other than having CF pause at hibernate, and unpause after. I'm assuming it's a problem with the way Windows resumes. It's playing what it had left in the audio cache just before hibernation, then it 'hangs' while everything is resuming, then starts up again. Mine always does it right before CF comes back up on the screen as Windows still has the 'resuming windows' bar on the bottom.
  9. #139
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Jahntassa
    the version in my car wakes up fine from hibernation... I will look into this though... I was about to add a pause on hibernate and unpause on resume anyway... so I can have it fade back in on resume...
    david
  10. #140
    Quote Originally Posted by Mbai2
    it is suppose to, just a bug most likely... I will check it out...
    david
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
