As far as the jittering after hibernate, I originally had this problem when using NMC. It would last aproximately 10 seconds or more, unless i paused it and then resumed. I switched to Frodoplayer and did not have that problem. Haven't noticed it in any Centrafuse versions either. I could not pinpoint what caused it.
Good idea on the fade in on pause. That would be a great addition on resuming from hibernate as well. I currently use a program that will run a script before hibernate to drop the volume to a low level so that it doesn't blast if i left it loud when i had shut it off.
The new Always on top function in 1.4 works with my GPS most of the time, though it still blocks some of my windows. How does the On Top determine what windows should be on top?
LinkBack URL
About LinkBacks
