Page 16 of 28 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 271
Thread: Centrafuse 1.4 Bugs
  1. #151
    Raw Wave justintime's Avatar
    Apr 2005
    Double-Clicking an Album when in Single-Click mode -> issues
    1) Set CF to enable Single-CLick mode.
    2) Go to Media Manager / Library / Artist ... and choose an Artist
    3) DOUBLE-CLICK an album picture
    4) Click LOAD button to load entire album
    5) Problem: CF complaints "Nothing Selected"
    I guess there is no reason to double-click when in single click mode, but it does happen every now and then with touchscreen monitors by mistake
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #152
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    Quote Originally Posted by justintime
    Don't know if this has been reported, but if I hibernate while playing music (mp3 files), when I wake up from hibernation the music continues playing where it left off, but the sound is all jumpy and jittery for the first several seconds.
    In one instance, the only way to resolve the problem was to PAUSE and UNPAUSE... then everything was normal.
    Is it just me?
    I fix the studder music problem when the system resumes from hybernation.
    It's some sound cards causing the problem. That's why everyone does not experience it.
    What you have to do is turn down the sound hardware acceleration. To do this go into control panel => sounds and devices => audio => sound playback advance => performace. Bring down the slider to basic acceleration.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  3. #153
    Oct 2003
    SOCAL
    Quote Originally Posted by S7347H
    to run a program before or after hibernate, i use a program called suspendtrigger. I pair this with executing frodo's setvolume program through a batch file. It works best if i set it to execute the batch file before hibernation, otherwise it doesn't run it soon enough on resume to actually start at the set volume when centrafuse starts playing.
    Here is the link for suspendtrigger. Suspend Trigger
    Is it possible with this program to have it execute an internet connection when the system resumes from hybernation.
  4. #154
    Oct 2003
    SOCAL
    Quote Originally Posted by SOS
    veetid:
    Hey, I had this problem on 1.3 also, but was hoping for an automatic fix, but 1.4 has the same problem (both original and other skin).
    When I wake up from hibernate in CF (where it was left off) the screen is just blank. Nothing wrong with the hardware, because I see the boot process, it just when the OS is up and CF takes over the screen blanks. The music plays in the background, I can use the touch feature of the screen and skip forward (because I know where the buttons are). Some times after 5 minutes and some times after 30 minutes or more the screen wakes up. I also tried pushing stuff to see if I could make it work, but havent found a good combination.
    Im running on a Epia V10000 board with and NVidia PCI board as the primary board....
    What kind of debugging can I do to help you find this "bug"?
    This was a problem for me as well in other front ends. It's not CF causing this problem it your graphic card. Try playing with the video and 3D acceleration levels. Most likely they are to high.
  5. #155
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    So it's basically the sound/video caches causing the problems. I'll deal with it as I really don't want to turn off the hardware accelleration..
  6. #156
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    Pause only temporary
    Howdy David,
    if I pause a video file to say go out for tea, I find that CF un-pauses and continues to play the file, without a STOP button the only way to truly stop a playing file is to clear the playlist & queue list. Or exit CF.
    IIRC it will pause for about 5mins then it re-starts...
  7. #157
    Apr 2005
    Quote Originally Posted by inniss777
    you would have to find a program that would automatically do that. The suspendtrigger program will only execute a program before hibernate and or after hibernate resumes.
  8. #158
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Tuned Vitesse
    Howdy David,
    if you pause audio does it stay paused? I will look into the video pause problem...
    david
  9. #159
    Oct 2003
    SOCAL
    Quote Originally Posted by Jahntassa
    you would not notice any difference endless your are using your system for intence gaming and fiber optic sound.
  10. #160
    Jun 2004
    The North, Manchester
    When dragging and the letters pop up (auto seek) is Cf supposed to jump into the first album of the letter selected?
    I.E Scroll to R - and it will jump into the first album begginning with R, which is really annoying if i want the second album beggining with R...
    Can it just display results??
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
