Page 18 of 28 FirstFirst ... 89101112131415161718192021222324252627 ... LastLast
Results 171 to 180 of 271
Thread: Centrafuse 1.4 Bugs
  1. #171
    Newbie relidl's Avatar
    Jul 2004
    Quote Originally Posted by kbreeden
    David,
    It's probably a feature change rather than a bug, but I'll agree with those who think it would be much better for random play to be shuffle play. If I play an album in random mode, it might play the second song three times before it plays the twelfth song.
    I think this would be great. A few times when skipping a song I've had to skip it multiple times since it keeps coming up as the next song in the que.
  2. #172
    Raw Wave justintime's Avatar
    Apr 2005
    Wow,... the hibernation and music stuttering problem is very REAL. I hope this gets fixed, because as-is, it can really drive you INSANE!!!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  3. #173
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime
    I still can't reproduce this one on any of my M10000's... I have a had centrafuse running in my car using hibernation for about 5 months...
    I plan to pause and resume on hibneration for cross fading anyway... hopefully this will fix it for those having problems...
    david
  4. #174
    Apr 2005
    FWIW, it occurs on my Biostar M7NCG400 motherboard... don't really have an EPIA but hopefully someone else can verify? I know of at least one other poster here having the same issue, reported a few days back.
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
  5. #175
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    I can verify this. I am getting stuttering problems. About every 10 minutes i'll get a 1-2second pause in th emusic and then it will start right back up.
    Hibernation issues? the only hibernation issues i'm experiencing have to do with GPS, specifically iguidance and my bu303 starting back properly after resuming from hibernation.
    My exact setup can be found here: http://www.maximapc.com/info.php
  6. #176
    Maximum Bitrate Vchat20's Avatar
    Jan 2005
    Warren, Ohio, USA
    although i only tried once, i didnt get stuttering. keep in mind this is on a pretty beefy system (2GHZ, 512MB RAM, 128MB Radeon 9200).
    really, im not suprised thats the case. cuz when you reload from hibernation, the computer will take some cpu cycles getting everything situated again such as the page file and whatnot. slower systems such as your epia's will fall victim to stuttering as youve mentioned.
    Your everyday carpc geek and tech guru at your service. *bow*
  7. #177
    Aug 1999
    Vchat, while that could be true; these issue did not occur with previous versions of Centrafuse.
  8. #178
    Jan 2005
    Warren, Ohio, USA
    most likely due to the new audio system david is using. last i checked, he is no longer using the windows media com objects like he was in CF 1.2 and earlier.
  9. #179
    Aug 1999
    That's what I was thinking too; i figured with this code rehaul that he re-coded how he handled media functions.
    I had been wanting to upgrade to a faster system, i'm just concerned that he has no problems and i'm running about the exact same specs as he is.
    Only time will tell.
  10. #180
    Jan 2005
    Warren, Ohio, USA
    only thing i can suggest to either regular users or david is to run CF at an elevated cpu priority (above normal is probably the best. any higher and CF will probably become unresponsive). this way it has higer priority over everything else that is currently running and it SHOULD eliminate the stuttering.
    edit: btw, f you dont know how to do this, just open task manager (CTRL+ALT+DEL or taskmgr in the run applet), find Centrafuse on the processes tab, right click it, go to "Set Priority", and click AboveNormal.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
