Page 2 of 28 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 271
Thread: Centrafuse 1.4 Bugs
  1. #11
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    I am also.
    http://www.mp3car.com/vbulletin/atta...id=17572&stc=1
    What it looks like in my directory
    http://www.mp3car.com/vbulletin/atta...id=17577&stc=1
    The tag as seen from the Properties tab.
    http://www.mp3car.com/vbulletin/atta...id=17578&stc=1
  2. #12
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    no DVD audio
    audio works fine for music and videos but no dice on DVDs
    also,
    this is on a laptop here
    nothing really special as far as audio goes, one thing to note this laptop does not have an audio IN (other than a mic) a little weird if you ask me.
    I havent tested on any other desktop pcs yet or my car which dosent have a dvd player.
  3. #13
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by TimmyM
    I am also.
    whats the difference in the "losing grip" file compared to the others? It is the only one that showed up correctly... Send me a couple of those files and I will look into it...
    david
  4. #14
    Quote Originally Posted by liquid_smoke
    no DVD audio
    volume can sometimes be really low on some DVD's... Does it not work with all DVD's? does the audio work with DVD's in WMP? what codec are you using?
    david
  5. #15
    Aug 2003
    Chicago
    Quote Originally Posted by veetid
    david
    just edited my post,
    the volume isnt low, its not there at all, i have it cranked up to 100%
    audio works fine in wmp, power dvd, and MCE2k5
    The audio codec is from Nvidia for the 6800Ultra
    also, dosent matter what dvd i load
    another thing i noticed is when i turn on autoplay dics, it automaticly started playing the dvd in my drive when i load CF (disk was not just inserted) and after clicking the X to close the dvd and go back to music, about 2 min later it started playing the dvd again on its own. This happened about 5 times till i turned off autoplay.
  6. #16
    Aug 2003
    Federal Way, WA
    david
    Heck if I know! I've been trying to figure it out. I'll send you a couple that work and a couple that don't.
    I sent it but it's 20 megs. Hoefully your email server doesn't block it. Let me know if it does.
  7. #17
    Jul 2005
    Sweden
    Quote Originally Posted by Release Notes for 1.4
    ‘ character is no longer doubled
    But ' still is..
    Which is also the one I had trouble with from the beginning..
    /p
  8. #18
    Jul 2005
    Sweden
    About the wierd tags:
    I got one of those, re-tagged the file by first removing the tag and
    then adding it again.. Rebuilt the library and it was fixed..
    Don't know if this helps any, but that was how I fixed it..
    Cheers
    /p
  9. #19
    Mar 2005
    Sweden, Vessigebro
    Haven't seen that tagproblem
    I'm having problems with the adding of songs to the playlist. it will never add just one song, instead it adds the whole album i'm in even if it says song added, and I can't add more then one album because it just picks the album I added last.
    I hope thats a bug and that it isn't programed to be so.
    /Jonas
    Jonas
    Hardware: (95%) Paintjob is killing me. A good shutdown controller would be nice. Voicecontroller??
    Software: Beta testing for the gods!
  10. #20
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    First time setup needed every time at startup, No text in buttons
    Hello everybody,
    I did a clean install of my system this weekend. All the apps are working great. I also was verry pleased to see 1.4 release so my install is perfect up2date.
    But, every time i start up CF it says: You must enter setup
    The setting file gets updated, i also asks my to overwrite and it does.
    The next problem is i have no text in my buttons
    As you see on the screenshot i have attached there is no text in the buttons.
    Also i can click the button and i see the green light flash but nothing else on the screen changes.
    All my other apps work great.
    Here also my log file but i don't get what this means:
    31-7-2005 16:26:25
    Object reference not set to an instance of an object.
    at centrafuse.main.localskinsetup()
    31-7-2005 16:31:57
    31-7-2005 16:33:31
    31-7-2005 16:42:13
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
