Page 3 of 28 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 271
Thread: Centrafuse 1.4 Bugs
  1. #21
    Raw Wave justintime's Avatar
    Apr 2005
    Scrolling through lists changes current song 'focus'
    If you are scrolling page up / page down in a playlist (e.g.: you have loaded an album, and are now clicking the UP and DOWN buttons to reveal more songs in the list), CF will set focus to the first song on the displayed items every time you click UP/DOWN. The problem is that you might be playing SONG1, you click 'down' button to see what else is down there, and all of a sudden song #8 is hilited, even though you are playing song#1. What's even worse, is that if you now click the NEXT-SONG button (FWD button) it will jump to song #9 instead of going to song #2.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #22
    Jul 2005
    Sweden
    Adding to justintime's post:
    You can't pause a song either because of the selection moving..
    It starts playing the song selected....
  3. #23
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by paran0id
    But ' still is..
    Which is also the one I had trouble with from the beginning..
    /p
    can you send me a file that is causing this problem....
    david
  4. #24
    Apr 2005
    I get this error when trying to start CF 1.4
  5. #25
    Quote Originally Posted by Longitud
    Haven't seen that tagproblem
    I'm having problems with the adding of songs to the playlist. it will never add just one song, instead it adds the whole album i'm in even if it says song added, and I can't add more then one album because it just picks the album I added last.
    I hope thats a bug and that it isn't programed to be so.
    /Jonas
    do you have singleclick enabled? If so the logic is different... Everything you select is one level back... When you select an album with single click it automatically pulls that album up, but doesn't select anything in the new list... At that point the album is selected... so hitting load or "+" deals with the album... if you then select a song it automatically starts playing that song... You have less options when using single click, but there are only so many ways to implement it...
    david
  6. #26
    m-ruiter: It can't read one of your config files... you have something invalid in your config.xml or it's not valid xml... Did you manually edit any of these files? It could also be a corrupt or improperly edited language file or externalapps.xml...
    david
  7. #27
    S7347H: what OS? That is the very first part of CENTRAFUSE that checks to make sure no other instances of CENTRAFUSE are running...
    david
  8. #28
    Apr 2005
    This was also present in 1.3:
    If you do a "ADD MUSIC" (instead of rebuild) and select a folder, a dialog appears that says 'Rebuild / Close'. It seems like it is doing something in the background (adding the music as requested?) but you cannot click on any of the buttons. There is no progress display either. It's just a little strange, Im sure you'll agree!
    2002 Honda CR-V
  9. #29
    Quote Originally Posted by justintime
    it should be displaying files that it is adding... if you select a folder that contains filenames that are already in the DB, then they will not be added... If you wait does it display how many songs it added when finished? run it and do not try and click any of the buttons until it's finished and see what it says...
    david
  10. #30
    Apr 2005
    If I do not touch anything, the dialog stays on screen, no progress shown. When finished, it does show the total songs added.
    Note: I am selecting my 'Music' folder root, because as I understood it, this is the way to update the new files added (instead of doing a full rebuild).
    Quote Originally Posted by veetid
    david
    2002 Honda CR-V
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
