Page 4 of 28 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 271
Thread: Centrafuse 1.4 Bugs
  1. #31
    Raw Wave justintime's Avatar
    Apr 2005
    If Video folder not set, 'invalid directory error' throughout app!
    I have not set a video folder in settings. I dont have/need/want one
    So, if I happen to click on VIDEOS in the 'Browse By...' dialog, I get an error 'Invalid Directory'. This is OK. But now if I click on any other place (ALbums, Artist, etc.) I get the same error...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #32
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by justintime
    If I do not touch anything, the dialog stays on screen, no progress shown. When finished, it does show the total songs added.
    Note: I am selecting my 'Music' folder root, because as I understood it, this is the way to update the new files added (instead of doing a full rebuild).
    basically the status only shows files that have been added... so when you select your main music library it is going through all the files and deciding not to add them because they are already added, so you see no progress update... I will fix this... It does work like you think and will only add the new songs... Also I noticed if you try to hit close, it will not function, but once completed it will close really quick... I will fix this too...
    david
  3. #33
    Jan 2004
    NYC
    david any update on the tagging problem, i cant upload more then 2MB on my email client to send you some files
    I hope I dont have to redo my taggs again, do you think its def. a bug or are my taggs just messed up
  4. #34
    Quote Originally Posted by camsgs3
    I will look into it... I just got some files emailed to me... what paran0id said was interesting... not sure why it would read improperly for some... I am just hoping the files I get read improperly, if they read fine then it's got to be some type of encoding/localization thing...
    david
  5. #35
    Constant Bitrate m-ruiter's Avatar
    Jul 2005
    Kortenhoef
    Quote Originally Posted by veetid
    m-ruiter: It can't read one of your config files... you have something invalid in your config.xml or it's not valid xml... Did you manually edit any of these files? It could also be a corrupt or improperly edited language file or externalapps.xml...
    david
    I did a clean install of 1.4. I did not have 1.3 installed. Just clean XP with KLite codecs, PhoneControl, Freedrive and sorry Road Runner.
    I will try to install 1.3 and run 1.4 over it. Maybee that will solve it.
  6. #36
    Quote Originally Posted by m-ruiter
    you don't need to install 1.3...
    david
  7. #37
    Jul 2005
    Kortenhoef
    david
    I cant download 1.3 anymore stuppid me. 1.4 is it now.
    But i guess it is something that i took out with nlite ? to shrik and speed up my XP. The only extra thing i took out was COM+. Could this be the problem ?
  8. #38
    most likely... I do interop a couple of com's....
    david
  9. #39
    Jul 2005
    Kortenhoef
    david
    Dawn, that sucks. It speeded up 1 second of my boot process
    Thats gona be one week of roadrunner and a reinstall next week
  10. #40
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    Some Label Issues
    Misc label probs:
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
