Page 5 of 28 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 271
Thread: Centrafuse 1.4 Bugs
  1. #41
    Constant Bitrate lifeboat's Avatar
    Nov 2001
    Oregon Coast
    DVD Buttons
    When switching to DVD mode (no disc loaded) from any other mode, the buttons don't load correctly:
    IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
    Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
  2. #42
    Nov 2001
    Oregon Coast
    Problem reading APE Tags
    Doesn't seem to read APE tags correctly, it comes up with a bunch of "unknown". I have re-tagged the file but it still doesn't work, these tags do read correctly in other applications. First image is MP3 with ID3v1, second image is MPC with APEv2... the MPC file is the same one I emailed you before, if you want to test it.
  3. #43
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by lifeboat
    Misc label probs:
    what resolution are you running?
    david
  4. #44
    Nov 2001
    Oregon Coast
    Quote Originally Posted by veetid
    what resolution are you running? It appears you shrunk the width too much for my current skin...
    david
    It's 800x600. I just resized the images for posting here...
  5. #45
    you sure that's 800x600? I run 800x600 fine and the images you have posted don't appear to be 800x600... Here is a screenshot if it running 800x600 on my machine... I also loaded it up in 640x480 and looks good to... everything fit... not sure whats going on, but something's not set or working like it should for you...
    david
  6. #46
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    If I load a mp3 cd into my cdrom, it comes up in centrafuse with the name of all the songs as the name of whatever the last mp3 song playing from the hard drive was. It shows the correct number of songs on the cd though. This seems to happen with or without auto play enabled. Regular CDs work fine.
  7. #47
    Nov 2001
    Oregon Coast
    david
    I figured it out, my system was set for large fonts (120dpi), changing it back to 96dpi and rebooting fixed it and now it looks like yours. Can you make the Centrafuse fonts function independently of system fonts? I'm sure I'm not the only one using large fonts, on these tiny screens it's almost a necessity.
    EDIT: Ok, that was a bit dumb. Actually it was the display DPI setting that was 120, I just realized that fonts can be adjusted seperately. So, with display DPI set at 96 and fonts set to extra large, it does seem to work properly. Still not sure if this will work well for me, I do like having the display DPI at 120 because it makes other parts of the GUI easier to see as well. Thanks for taking a look.
  8. #48
    Constant Bitrate snmnetwork's Avatar
    Aug 2004
    Atlanta, Ga
    Quote Originally Posted by camsgs3
    this is what my nas directory looks like...... anyone else getting tagg problems
    Damn! I got the same music..lol
    Status: [|||||||||-] 90% finished
    My 2000 Chevy Monte Carlo SS Install
  9. #49
    Raw Wave justintime's Avatar
    Apr 2005
    Opaque background BEFORE overlayed screens/dialogs
    Minor detail...
    It appears that whenever you overlay a dialog/screen on top of the current interface, you are bringing the dialog up front FIRST, and opaquing the background SECOND.
    It is noticeable. Would be much nicer if you made the background turn opaque FIRST, and *then* overlay the new dialog/screen on top.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  10. #50
    Apr 2005
    Queens, New York
    David,
    IN System Info, under CPU Temp, it never says the temp all it says is °C. I have mbm5 running but never can get the temp. Also how would I change it to Farenheit?
    2002 Mitsubishi Galant
    Carputer Specs:
    Via M10K
    512mb Ram
    60GB HDD
    Souund Blaster Audigy2 NX
    OPUS ITX PC Case
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
