Page 6 of 28 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 271
Thread: Centrafuse 1.4 Bugs
  1. #51
    Raw Wave justintime's Avatar
    Apr 2005
    Lightbulb Single Click needs more thought
    The 'Single Click' function should be used only in certain sections of the system.
    One example where it should NOT be used, is the EQ presets. If I bring the list up, and I want to delete a preset that already exists, I would normally select the line and then hit the 'minus' sign.
    As is right now, as soon as I click the line it loads the preset, and does not give me achance to delete!
    OK, I think this should be the rationale behind the use of 'Single Click':
    -If there is any further possible action after a 'click', then that should never be a 'Single Click' function.
    So, generally speaking, if the interface provides means of doing 'more stuff' with any given selection, then that should not be 'Single Click' enabled.
    Seems like there are only a few places where you'd want to allow 'Single Click'. Mainly the playlists, directories, etc.
    Thoughts?
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  2. #52
    Jul 2005
    Sweden
    Quote Originally Posted by veetid
    can you send me a file that is causing this problem....
    david
    Nvm.. Just noticed it was my playlist that I copied from 1.3
    Added the file directly from the library and the ' was fixed..
    Just my stupor messing things up..
    Thx anyway
    Cheers
    /p
  3. #53
    Variable Bitrate inniss777's Avatar
    Oct 2003
    SOCAL
    David: Awsome job on the bug fixes.
    On thing that I did notice is that the eq does not control my videos levels. Only music.
    Also the treble and bass knobs have no effect on no matter what I am playing. Thanks.
    Opus case. MB 899 core duo 2.0ghz
    Dual vga out, 400 gb hard drive, Centrefuse front end
    zapco 1000.4 for zapco 6.5 componets
    zapco 1100.1 for 2 13" W6.
  4. #54
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Cheekz185
    David,
    IN System Info, under CPU Temp, it never says the temp all it says is °C. I have mbm5 running but never can get the temp. Also how would I change it to Farenheit?
    if there is no temp then I was unable to retrieve the value form WMI... this only works on some systems... I am looking into a better way to query that informaiton...
    david
  5. #55
    Quote Originally Posted by inniss777
    the treble/bass knobs just move small rnage in the EQ... so if the EQ works then they should be working...
    The EQ will not work with the videos... I currently have no control over the video audio stream...
    david
  6. #56
    how does this sound for singleclick...
    In media manager what I did was when singleclick is enabled it goes to the next level automatically, but your selection is what you clicked... then nothing is selected by default in the next level...
    basically I just need to have singleclick stop working at the last level or the end of the line... so it would always be singeclick in dialogs like presets and on the main media screen... since it can't go any deeper... but in media manager it would go unitl you hit an actual song/file...
    that sound about right?
    david
  7. #57
    Apr 2005
    I think I understand what you're suggesting, and it makes sense.
    However, on the presets for EQ, it cannot be singleclick. Yes, it is the 'end' of the 'tree', but you can't assume that for that reason there is no other possible selection. Did you see my example above, re: deleting a preset? There are more possible actions, even though it is the end of the tree...
    EDIT: I re-read it again. You're saying at the end of the tree it will NOT double-click for you, right? Yes, I think that way it will work well.
    david
    2002 Honda CR-V
  8. #58
    Apr 2005
    XX of YY files -- not updatinng correctly.
    Incidentally, I noticed a bug related to this. If you are navigating the 'Tree' in media manager (e.g., by Genre) when you click on a Genre, it goes to the next level down the tree, but it does not correctly update the XX of YY files display at the top right. It will show the PREVIOUS level's totals. (e.g.: 14/22)
    I believe this applies throughout.
    2002 Honda CR-V
  9. #59
    Oct 2003
    SOCAL
    Is the video stream piggy backing of windows media player. As far as the bass and treble sliders are you saying that they also have no effect on video as well?
  10. #60
    Apr 2005
    Cannot select a song in the list after performing SEARCH
    If you perform a media SEARCH, and get your results list, you are not able to select a single line item. It basically selects and immediately de-selects. (never gets to actually hilite the line).
    Looks like this is related to Single Click mode. Disabling Single-Click mode fixes it.
    2002 Honda CR-V
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
