Page 8 of 28 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 271
Thread: Centrafuse 1.4 Bugs
  1. #71
    FLAC djmickyg's Avatar
    Feb 2004
    when i running map monkey embeded then i close map monkey via the map monkeys menu. it closes both MM and the laucher and there is no way for it to re open.. aarrg
  2. #72
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Quote Originally Posted by Vchat20
    really odd. cuz i got the same exact problems as you. whit screen with a red x, .net errors, the works. and the uninstall/reinstall worked. are you sure its not howing more than one instance of CF in the add/remove programs?
    only other wild guess suggestion i have is to redownload CF again. might have somehow got corrupted.
    Did you set it to a different skin? Older skin files WILL NOT WORK with 1.4. Set it to the Blue Ice skin until people start rebuilding other skins.
    I had the same problem when I tried to switch to my old 1.3 skin.
  3. #73
    Maximum Bitrate CavityCr33p's Avatar
    Jun 2003
    Arkansas
    I didnt even get to pick another skin, this was a completely fresh install, happened during installation.
    2000 Sunfire build 100%, or is it ever really 100%?
  4. #74
    May 2005
    Conyers, GA
    Happened during installation? Like when you ran the setup file, or after CF was installed, and you had to 'enter setup'?
    I had to manually delete the 'Flux Media' directory in Program Files after the uninstall, because it left my setup files in there..
  5. #75
    Zac
    Zac is offline
    Feb 2004
    VA
    Now I can't seem to recreate it but I've had the single click option turn off magically when browsing through media a few times in a row. Of course now that I'm trying to recreate it I can't get it to do the same thing... Just wanted to throw it out there to see if anyone else had this happen...
  6. #76
    Mar 2005
    Sweden, Vessigebro
    Quote Originally Posted by veetid
    Quote Originally Posted by Longitud
    Haven't seen that tagproblem
    I'm having problems with the adding of songs to the playlist. it will never add just one song, instead it adds the whole album i'm in even if it says song added, and I can't add more then one album because it just picks the album I added last.
    I hope thats a bug and that it isn't programed to be so.
    /Jonas
    do you have singleclick enabled? If so the logic is different... Everything you select is one level back... When you select an album with single click it automatically pulls that album up, but doesn't select anything in the new list... At that point the album is selected... so hitting load or "+" deals with the album... if you then select a song it automatically starts playing that song... You have less options when using single click, but there are only so many ways to implement it...
    david
    no, I don't have the singelclick enabled. if I say it this way: I'm in the album view, and I wan't to add two albums. If I then add with pressing the "+" it says album added and then I move to the other album and add this and it says album added, then I press load and the album that is in the playlist is the album I selected last, the first isn't in the playlist. tested with singelklick and without, no difference. also the other way around with the albums, still the last album gets added.
    /Jonas
    Jonas
    Hardware: (95%) Paintjob is killing me. A good shutdown controller would be nice. Voicecontroller??
    Software: Beta testing for the gods!
  7. #77
    Feb 2005
    Hibernate/Resume Signal
    It seems that embedded programs still aren't receiving the hibernate/resume signals. This is important because some embedded programs rely on this signal to initialize properly after resuming.
  8. #78
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by djmickyg
    hit close in the embedded window toolbar, then it will reload when you click to launch the app again...
    david
  9. #79
    /Jonas
    load loads whatever is selected... it is like play now... after you add both albums to your "queue", simply click queue on the left and then hit load...
    when load is clicked while browsing in the library it auto clears the queue and loads the current selection... this is to allow easy music browsing to simply just play what you have selected... Otherwise simply add to the queue and click queue on the left before you hit load...
    david
  10. #80
    Oct 2004
    Washington
    david,
    after a clean install and re-install of 1.4, i cant get any albums to be recognized in that selection. it just shows one "unknown album" and when i click that it shows all my songs under the heading of "unknown artist" then proceeds to show the artist after that.
    please see attached pics for example...i even changed a few of the folder jpegs to pngs, and they still dont show up.
    also, (sorry if its in here somwhere) some ext. apps are still opening down in the lower right hand portion of the screen. it still resets correctly after you hit "apps" again and then the same program...
    FYI...
    thank you for all your effort and time.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
