Page 9 of 28 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 271
Thread: Centrafuse 1.4 Bugs
  1. #81
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by Tim97rs
    david,
    after a clean install and re-install of 1.4, i cant get any albums to be recognized in that selection. it just shows one "unknown album" and when i click that it shows all my songs under the heading of "unknown artist" then proceeds to show the artist after that.
    please see attached pics for example...i even changed a few of the folder jpegs to pngs, and they still dont show up.
    also, (sorry if its in here somwhere) some ext. apps are still opening down in the lower right hand portion of the screen. it still resets correctly after you hit "apps" again and then the same program...
    FYI...
    thank you for all your effort and time.
    it can't read your tags for some reason... Did the tag reading ever work for you in 1.4? I changed the tag reading completly in 1.4 from 1.3...
    this is a timing issue... sometimes my app sends the maximize command before the embedded app is ready to receive it... I will work something out with this...
    david
  2. #82
    Constant Bitrate skydiver's Avatar
    Nov 2004
    southampton (UK)
    BIG problem david
    when running CF 1.4 the program "wmiprvse.exe"
    wich is part of windows go's through the roof every 10 secs or so not good anyone else getting this or is it just me ?
    Program aborting close all that you have worked on,You ask to much. You step into the stream,but the water has moved on, This page is not here. Chaos reigns within, Reflect,repent,and reboot.Order shall return
    The car
  3. #83
    Jan 2004
    NYC
    Quote Originally Posted by veetid
    david
    whats weird is that in 1.3 CF didnt read any of my WMA files right, now in 1.4 its reads my WMA files perfect, but all my MP3 are messed up......
    So david do i have to redo my taggs again or is it a bug in CF
  4. #84
    Oct 2004
    Washington
    heres the weird thing... on my desktop, v1.4 works fine... i get my cover art, the highlighted selection bar moves up and down each individual choice..
    but on my carputer it does what i described already... and it moves through the choices by "pages" rather than individual songs, and it doesn't highlight any choice.
    i have xp home on the desktop and xp pro on the carputer if that helps any....
    and heres the other weird thing... per my other issue in another post about the DVD not working, it works on my desktop, but not the carputer...
    could it be an XP version issue?
  5. #85
    Quote Originally Posted by camsgs3
    are you getting the weird characters problem with your mp3's? If so I have fixed this problem... It was a unicode issue...
    david
  6. #86
    it is basically having trouble opening the files and reading the tags, so it defaults everything to unknown... Do you have any strange permissions on the music folder in the car?
    Does the DVD work in WMP? this is most always a codec problem...
    david
  7. #87
    Quote Originally Posted by skydiver
    BIG problem david
    Disable AutoPlay and let me know if it goes away... I use WMI to query the drives to check for disc insertion...
    that is the only WMI query I run other than when you click system information...
    david
  8. #88
    Nov 2004
    southampton (UK)
    david
    thanks david that did it
    i noticed it on fullscreen vis (slowed right down ) and that was on a 2.8 pc
    again thanks
    The car
  9. #89
    again thanks
    it shouldn't be doing that... I will track it down...
    david
  10. #90
    Raw Wave justintime's Avatar
    Apr 2005
    Visualization does not scale correctly
    If you changeb the size of visualization, the widow size changes, but the content does not scale. Is this a bug?
    Eg., try:
    <VISUALIZATION>
    <X>22</X>
    <Y>64</Y>
    <WIDTH>40</WIDTH>
    <HEIGHT>40</HEIGHT>
    </VISUALIZATION>
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 08:12 PM
  2. Release 1.4 CENTRAFUSE BETA 2
    Last Post: 08-02-2005, 11:20 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. New Release CENTRAFUSE 1.1
    Last Post: 01-18-2005, 10:17 AM
  5. [OFFICIAL THREAD] NMC 0.7 alpha.1 bugs
    By netsuo in forum NeoCar Media Center
    Last Post: 11-09-2004, 06:02 PM
