Only one character missing from time now!! got 08:2 thats all so far!!
post all the 1.4 bugs here...
Here is an updated list of the known bugs in 1.4...
Change initial check from get processes to find window (performance counter problem)
Embedded apps don’t’ receive power mode change event
Rear/sub/center need to increase with the master volume
Scrolling arrows and single click
When auto play is enabled it constantly tries to play DVD
Hold and jump screws up with single click
When single click is enabled it only needs to work on directories/upper level selections
Display file type instead of MP3 in the play mode label
Unicode tags are improperly read
Scrolling through list changes song focus, messes up next song and pause
Add music shows no update when scanning folders with files already in the DB
If no video folder is specified and you enter this section, you can’t get rid of “invalid directory” message
DVD player shows radio buttons when entered while in radio mode
Data CD doesn’t properly clear playlist
Remove temp measurement when no temp can be read
Singleclick doesn’t update listcount properly when items are selected
Check search results selection when in single click mode
Database fields are too small
External apps don’t full screen on initial load
Auto play causing problem with wmiprvse.exe
Visualization doesn’t properly scale
Cross fade not working when playlist advances tracks
Maintitle does not update properly (shows old song sometimes)
david
all my numbers are there... im in 800x600 on a 7" xenarc...
my tags seeem all messed up now when i browse , there where working great in 1.3....i didnt change anything
1-12 are tagged ok, 13-32 look like this
I am reading the tags completly different in this version... 1.3 only supported ID3V1... 1.4 supports just about every tag format there is... Is it only with those particular files? can you send me a file that is messing up?Originally Posted by camsgs3
david
Originally Posted by veetid
ok its seems that all my tagges are off now, from 1-12 they have the artist names but for example when i click on jay-z there should be 13 albums, only 1 is showing, with one song that looks like this
this is what my nas directory looks like...... anyone else getting tagg problems
Mine is working fine. What file format are you using?
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
camsgs3: if you can send me a handful of files zipped that are reading improperly to support@fluxmedia.net I will figure out what's going on... Appears like some type of encoding issue, not sure... What format are the files, mp3?
david
yea mp3, seems my wma are reading right...ill send you someOriginally Posted by veetid
